2023-11-28
10:28 AM
2024-09-26
01:55 PM
Doreena Deng
I have a list of favorite windows for a specific projects, but sometimes I change something in one window and I would like to redefine that into my previous favorite but the redefine opton is turn off. Then I have to open the settings for my favorite, make all the changes I already did in the window and then redefine the favorite. It would be faster if I can change a window and transfer those changes into an already made favorite. It´s that possible?
Solved! Go to Solution.
2023-11-28 10:47 AM
Thanks for your quick replies. I found the solution here:
https://help.graphisoft.com/AC/26/INT/_AC26_Help/020_Configuration/020_Configuration-60.htm
2023-11-28 10:37 AM
I have just closed Archicad but I am pretty sure if you have your changed window selected, then you can redefine the favourite.
2023-11-28 10:42 AM
Redefining is possible. Are you using the favorite palette or the tool dialog?
2023-11-28 10:47 AM
