Jim Allen
Conditional branching (again) - use of IFS
I really struggle with multiple conditions in GDL.
The IFS command seems to be the simplest and does what I want but the AC27 GDL editor doesn't like it.
I'm building a parametric manhole object, and need to set the size based on the depth and number of branches.
The parameters are these:
  • If there are more than 3 branches in the manhole (from the user inputs) - set the manhole length to 1370
  • If the manhole depth is greater than 900 (and there are fewer than 3 branches) - set the manhole length to 1250
  • If there are exactly 3 branches in the manhole (and the depth is greater than 900)- set the manhole length to 1030
  • Otherwise (if depth is less than 900 and there are fewer than 3 branches) - set the manhole length to 800
This would seem to do what I want according to the  user guide (https://helpcenter.graphisoft.com/user-guide/88992/)
IFS (numbranches>3, mhlength=1370, ZZYZX>900mhlength=1250,numbranches=3,mhlength=1030,TRUE,mhlength=800)
Yet I get this error when it is checked:
Missing CALL keyword (not recommended)
at line 56 in the Master script of file BG_Manhole_Rect_v0.1.gsm
Obviously I'm doing something wrong, I'm just not sure what. Any ideas?
Archicad 28 UKI | OS X 14.7 Sonoma
3 Replies 3
runxel
Hey Jim, you're conflating GDL with Expressions here. So no wonder it does not work. What do you actually want to do?
GDL does not support IFS.
A_ Smith
scroll to IF
AC 22, 24 | Win 10
Jim Allen
Thanks!
Thanks makes sense - pity...
It's all documented in the original post - I think.
I'm going to have to turn that into horrible nested statements. I hate the GDL implementation of conditional branching ...grr...
On a more positive note, I'm going to use your LocatorLX script as a template for the 2D labels, most of the scripting is done, so that will save a lot of time.
I should then have some nice parametric manhole objects I can drop into a model use as connection points for drain runs, and schedule.
