Martin Walter
Reveal to wall core input field missing
For the standard Archicad-windows the reveal to wall core can be set with an input field:
But in my self created window the input field is missing:
Does anybody know, what shall I change in the script to show the input-box?
AC22-27, Windows 11, i7-1355U, 32GB RAM, 2TB SSD
1 Solution
Martin Walter
I found out that ac_wido_hide_options=3 causes this behaviour.
Go to post
4 Replies 4
Jochen Suehlo
Please check, if you have a HIDEPARAMETER command with the Parameter "ac_revealToWallCore"
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
Martin Walter
There is no HIDEPARAMETER command with the Parameter "ac_revealToWallCore".
Martin Walter
Peter Baksa
Here is the documentation of the available values: https://gdl.graphisoft.com/reference-guide/parameters-read-by-archicad#AC_WIDO_HIDE_OPTIONS_gdlgloba...
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
