Display malfunction of Graphisoft ID dashboard
Learn more
felipetsk
Scripting tabs with bugs
Hey guys! recently i've got some dificult with custom script editor in objects at archicad 27 and still's on 28. Idk why it gets automatic randomly spaces, drop lines, del my script and other stuff, anyone with same problem? There's an way to use VSCode to scripting in GDL? What kind of workflow works on?
Thanks!
Difficulties with 'Custom' script editor?
Or do you mean the built-in default GDL script editor?
If it is a custom editor, you will need to follow that up with who ever created it.
If you mean the built-in editor, I have seen it where what you type in a script window is not necessarily what gets added to the script.
It seems to be especially bad if you have unlocked a script in a free floating window.
But it doesn't happen all of the time and it is hard to pin down.
