Nader Belal
Mentor
UI_PICT_Button and email
Hi everyone,
GDL has UI_BUTTON function that enables the library part to do certain functions, by selecting the "Type" of function we want. Same goes with UI_PICT_BUTTON (with the obvious differences).
And from the different "Type"s available, is UI_LINK, which if used and pressed by the user "the URL in expression is opened in the default web browser" (copied from GDL Manual).
How to make a UI_BUTTON if pressed it will open a new email with the desired email address to be sent ?
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
1 Solution
Jochen Suehlo
I use this routine:
str_version = "0.23"
UI_BUTTON UI_LINK, "Support Request", 340, dy - 5, 100, 25 , 1 , \
"mailto:[email protected]?subject=Support request for bp_fallrohr_22 " + str_version + "&body=Hello Joachim, %0A%0A" UI_TOOLTIP "send support request"
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
Go to post
2 Replies 2
Jochen Suehlo
I use this routine:
Nader Belal
Mentor
Thank @Jochen Suehlo , it worked as a sharm
