2023-02-11 01:15 AM - edited 2023-02-11 01:25 AM
Hi folks,
I am looking for a proper way to work/develop on a gdl-lib containing about 200 objects in a team of 5 persons.
I had a look to GIT, but there binary files are problem...
What do you use for colarborate, versonaring and merging .gsm files?
...or has anybody experience using/loading the objects directly in .XML format in AC?
best regards from Vienna,
Yours, Klaus
Solved! Go to Solution.
2023-02-11 02:45 PM
Do not use binary files (.gsm) on github. Use text format (hsf) which is suitable fot github workflow.
There are two options:
1. Edit your library files (gsm) in AC's object editor, then use lp_xmlconverter.exe to convert them to hsf and commit+push your edits to github.
2. Edit hsf files with external editor. I use vscode editor for editing scripts in hsf folder structure. After saving a script, gsm is auto generated with aftersave hook and lp_xmlconverter.exe
Switching to AC, I added a “Reload Library” button to my toolbar to update edited objects
You can check build scripts of my library directly on github
malamalca/ar_library: ARCHICAD Library of GDL objects (github.com)
2023-02-11 02:45 PM
2023-02-16 10:34 AM
Hello @Miha Nahtigal ,
This is an interesting workflow. I wanted to try it but your README is only 5 lines long, is it possible to know how the folder structure should be ?
2023-02-18 01:48 PM
Dear Miha Nahtigal,
thank you for your answer and the great workflow. 😀
It is great, because one of "my" developer partners work only on the binarys directly in ARCHICAD-Editor. He do not even know the ASCI-Formats for GDL... 🙄
so he need not deal with the formats - I will make him a bundle of batch-scripts and he
When I understand you right, the same workflow is possible using XML instead of HSF format, isn't it?  -  I have a lot of practice on the XML-formated-lib-objects and also some useful commandline-scripts adding or alter code in all xml-objects in a folder.... etc.
Best regards from Vienna,
Yours, Klaus
