daviiiiidave
VSCode - Language Server - GDL Syntax
Hey Com,
did somebody ever tried to make a GDL language sever für VSCode?
Does somebody use the Sublime GDL Syntax by runxel?
ARCHICAD 19-25, Student & Full Archicard, CI Tools, Germany
Mifcom Renderbox AMD Ryzen 9 5900X GeForce RTX 3070 TI 32GB RAM 980 PRO SSD Win10
Thinkpad P52 4K i7 8850H NVIDIA Quadro P3200 (6 GB) 32 GB RAM SSD Win10 Pro
6 Replies 6
Hello daviiiiidave,
I invite you to read this Pavlo Menshykh presentation :
https://www.graphisoft.com/users/bim-case-studies/gdl-coding-with-archicad.html
I haven't understood yet how to use it but I'm sure it's a great way to write scripts.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
runxel
Great article! Pavlo makes wonderful stuff, a brilliant mind truly.
(But the article has nothing to do with what Dave mentioned, tho 😉)
Christophe, my friend: you can always ask!
(I will make a demo video soon, just didn't find the time for that)
Thank runxel for amazing tool!
leceta
this would be much appreciated, thanks
leceta wrote:
(I will make a demo video soon, just didn't 192.168.100.1 192.168.1.1 jpg to pdf find the time for that)
runxel
I have looked into it (very briefly).
Microsoft ist still changing quite a bit of the spec, so you'ld need to update often to comply.
A big advantage however is, that the language server in itself can be agnostic, so you would only need to write a plugin for your favorite tool which connects to the LSP. GDL in Emacs? No big deal then.
Still, building that LSP is quite a task, if we ever build one (actually looking at you GS! Do some Open Source work, already! McNeel is leading the way...).
