2025-11-03 02:28 PM
Hello Everyone!
I like to work on GDL objects with smaller window size, so i can easy switch between them. However these window size handling buttons are missing in the upper right corner, even is the latest AC28 build. But they are actually there, you can click on them, and they function as intended, so you can minize to tray, resize and close them. If you try to click on them, you will see it!
See images.
Thanks
2025-11-04 02:39 AM
Assuming you are running Dark Mode: https://community.graphisoft.com/t5/Modeling/Missing-Sub-Window-Diplay-Buttons/m-p/628554/highlight/...
a week ago - last edited a week ago
WHY US NEVER FIX THIS BUG??
a week ago
@mrsalomao ... the same reason they never fixed the missing model view option bug. They DID 'fix it'; just not all the way. Good enough is always the target!
a week ago
If the buttons do not show in AC29, you should submit a bug report as by their wording, AC29 has "full support for dark mode on Mac". If this statement is retroactive to AC28 is a different question...
