2024-01-17
11:15 AM
2024-09-26
01:27 PM
Doreena Deng
Hi There,
i am working on automatic labels using custom picture method (gs_picture)
just wondering i cant figure out how the automatic / and non automatic placement is done.
i can give the label a fixed place, for example the object which has to be labeled is section / elevation 1500 x 1200 mm
i want the center label to be the center of the object.
i already requested the zzyzx en a parameter using:
rrr = REQUEST ("ASSOCLP_PARVALUE", "ZZYZX",
rrr = REQUEST ("ASSOCLP_PARVALUE", "A",
if gs_picture_name <> "" then
add2 -a/2, -zzyzx/2
picture2 gs_picture_name, AW, AH, 1
endif
Solved! Go to Solution.
2024-01-17 12:25 PM
Try the label set to zero routine. Just an idea, I do not know if it helps in your case:
add2 LABEL_POSITION[2][1] + LABEL_POSITION[3][1], LABEL_POSITION[2][2] + LABEL_POSITION[3][2]
2024-01-17 12:25 PM
2024-01-17
01:22 PM
2024-01-21
03:59 PM
add2 -ArtWidth/2, -ArtHeight/2
2024-01-17 01:40 PM
The values in the brackets are the Array-Values, because this Global Variable is an Array Variable.
The 2nd Value is either 1 or 2 for the x and y position
The 1st Values define the position of the label pointer, the starting point of the pointer (I think) and the starting point of the label.
