easyDoesIt
Elevation Number for Interior Common Elevation
Hi All,
I have been searching for the code to use in a marker object for the Elevation Number for Interior Common Elevation marker. I.e. it will be 1,2,3, or 4. I can see that the autotext number can be added in the Reference ID or Name fields in dialogue settings but want to reference directly in the library part. Have checked GDL manual and developer tool kit but can't find it. Any ideas?
I am guessing <MARKERNUMBER_R> AC_DrawingGUID_1 but that didn't work.
Just for reference this is different to the Drawing ID that is a parameter within the library part.
Cheers, Mark | archibites.tech | Wet Area Tool v2 | Parking v5 | Door Circulation Compliance | Multi-Label | Roof Slope | Wall Type Label
Brisbane, Australia
Windows based system on all versions of Archicad
1 Solution
easyDoesIt
Thanks Peter,
I was actually after the Elevation Number rather than reference ID. But realised I can get this without parameters. ie Upper is always 01, Right is always 02, etc.
Brisbane, Australia
Go to post
Peter Baksa
The interior elevation IDs are parameters:
AC_MarkerText_3,
AC_MarkerText_5,
AC_MarkerText_7,
AC_MarkerText_9
The referred drawing IDs are
"<MARKERDRAWINGNUMBER_R>" + AC_DrawingGUID_...
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
easyDoesIt
Thanks Peter,
Brisbane, Australia
