2004-12-02
04:06 AM
- last edited
2 weeks ago
Molinda Prey
2004-12-04 06:54 AM
2004-12-04 05:15 PM
Richard wrote:I have not heard that CA can handle something like Eureka Tower.Djordje wrote:Djordje - Other than the multi-user environment, what do you believe defines "class" in this case?
Also, you can not compare ArchiCAD and Revit with Chief Architect; if you compare, it shoudl be the same class of software.
2004-12-04 05:26 PM
Scott wrote:Sorry, Scott, but this is simply not true. The Autodesk deadlines ran one version back. Support? Back home, I drive a 1965 Beetle. Still can find parts for it.
The 'deadlines' are imposed by the age of the software. Autodesk cannot continue to support old software. If they had to, they would need to provide support back to 1.0.
Scott wrote:Quite callous. Especially if you are on the subscription scheme, which should be on a yearly basis the same as a full license plus upgrade.
The deadlines basically mean that Revit has moved on and dropped support for old software. You can continue to use it if you'd like, but when it comes time for you to move on, you will need to purchase the software outright again.
2004-12-04 06:25 PM
2004-12-04 09:22 PM
Djordje wrote:Since there's been discussion, let me add:
2004-12-05 02:06 AM
2004-12-11 08:28 AM
Adalbert wrote:A major consideration is what type of practice you picture your future in, or you would like to flow to in the future. The larger the practice, the larger the personnel dynamics, the larger the flow of CAD files with the outside world, the higher the costs of speaking a different language. The smaller the practice, the lower those costs and the higher the profits of maximizing productivity even if it is not the market leading program. (In say spreadsheets you don't have that dilemma: Excel is the absolute best, and it is also the standard.)
I for one at the time I decided for Archicad I was sure it will conquer the marker, but I was wrong and it did not.
2004-12-11 04:49 PM
2004-12-11 05:58 PM
2004-12-12 07:23 PM
Adalbert wrote:Don't think so. Not because of the software, be it ArchiCAD or Revit, but because of the nature of the industry. As long as the authorities want paper, and as long as not knowing how to send email, make a PDF, or scan something means that you are illiterate, it will not happen. No non-drafting software will be a standard.
Ignacio,
You are right as far as the past is concerned but at this point we have a competing software equal or close to be an equal with AC. Unfortunately this software is in the hands of the most powerful player in the field and it may very well become a standard, so the picture you projected is far from being an accurate one.
Adalbert wrote:Quite, quite true. What works for you best is the best. Some would not require more power than X, some would want Gehry's CATIA based app. The trick is to recognize the value that XYZ software returns to your practice.
You are correct “ The best practice, in my opinion, is to use whatever works best for now and be prepared to change if circumstances dictate.” This is what I am talking about the “change if circumstances”.
