ArchiCAD is great—until you receive blueprints from 1985. 💀
I was stuck at my desk until midnight again yesterday. We all know how well exports and Xrefs work in ArchiCAD, but that ends the moment a client sends you a "dead" scanned image from the archives or a hand-drawn plan.
I’m tired of burning hours manually tracing rasters because no current tool can properly vectorize them for a clean BIM workflow. It makes no sense that in the age of advanced AI, we’re still doing this manually like it’s the 1900s.
I’m seriously considering developing a custom solution/add-on to fix this once and for all. I’d love to get your expert insight – it takes max. 1-2 minutes:
link : https://docs.google.com/forms/d/1quyW04z4KUqLNh2-vprnecr3Ov7-0_QV-96HeA0HUuc/edit
AC 7 - 27 SWE
MacBook Pro, M4 Pro
1 Solution
AllanP
Since the 1990's we used illustrator for this.
illustrator vectorize image
https://www.adobe.com/au/products/illustrator/vectorize-image.html
illustrator export dxf
https://www.adobe.com/au/creativecloud/file-types/image/vector/dxf-file.html
Does illustrator not work anymore?
Does Archicad no longer import DXF files?
This is the real reason to have an Adobe License.
P.S. this process used to take under a minute on old 1990's computers to get the dxf into Archicad from the scan.
I used to work for a company founded in the 1930's and we had a lot of Physical drawings that we scanned on a large format Scanner and converted to Archicad.
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
Go to post
21 Replies 21
Pavel_N
Can you please give me tips on AI models that can do this? I imagine the author's idea more as creating a professional working tool that does not require patience with AI. A plug-in adapted as much as possible for the BIM/CAD environment (layers, pens, curve optimization, built directly into AC), so that the user can find their preset and then this conversion is as close as possible to one-click. I have no doubt that AI will be able to do all this, but I don't know if it is so far that the outputs are usable without further work for the CAD world?
You are absolutely right that AI inside Archicad would be the ideal platform for these things.
