James B
Component Level Design Workflows - Conversation & feedback
Hi All,
Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.
To express design intent and extract data at a more detailed level, the component or skin level requires further data and flexibility. We already visualise these skins, have Offset Modifiers for Profiles to create smart parametric extrusions, and Component/Surface Schedules to extract data.
We plan to further develop the component/skin level of elements and expand existing functionality in that area, so we are exploring more about what you need. Some questions:
  • What type of data do you need to store in components/skins that may be separate or different to existing Building Material properties?
  • How is this data used and presented in documentation and schedules?
  • Renovation of components, are similar for the same composite/profile? Or mostly unique for all placed elements separately?
  • Modelling flexibility of components, in which common situations are you resorting to workarounds, like stacking elements, that existing composites/profiles with modifiers can't achieve?
  • Visualisation of components, in which situations do components need be visualised differently compared to the whole element? Such as requirement for submission to highlight structural skins.
As we progress in this area, your input will be invaluable to understand priorities and our direction moving forward. Thanks in advance.
James Badcock
155 Replies 155
Ahmed_K
Mentor
Hi insiders
Can we have an update on this development?
Thanks
Archicad 27
Windows 11 professional
Ahmed_K
Mentor
I'm deeply exploring the process of 4d and 5d modelling, and the site quantity survey to track accomplished work.
Component level design will fix alot of workarounds and impossible tasks , like skins by zone, skins by facade, floor finishes by zone, quantity of wall finish by zone faces, and more.
Now, the only way is to model each skin as a separate wall/slab,
Archicad 27
Exactly.  And Graphisoft realized this more than 20 years ago when they had the "Constructor" line of 4d/5d software (later sold) which had to re-model those elements.  It would be nice to see fine-grained component/skin/etc control in Archicad itself.
https://mail.aecbytes.com/newsletter/2004/issue_15.html
Ahmed_K
Mentor
here is a common exemple for me :
wall skins relation to zone is crucial,
when we make takeoffs, and to ensure all is correct, we need to se the relation of an element / component to the related zone,
this will be our starting point for quantity statements onsite, and for tracking site work evolution
Composite Wall 01 start from room 1 to room 2,
it's skins belong sometimes to room 1, sometimes to room 2, and some times to the façade
A small beam under the wall is used to cover the slab edge, it has the same material as the exterior wall finish.
To quantify materials there is a logic :
  • If it's interior : locate the material by it's zone
  • If it's exterior, locate the material on the façade.
you can divide the wall , and say, hey this segment is for room 1 and this is for room 2, ok it will work, nut not for too long :
  • The interior finish quantity comes from the component schedule, it can show the related zone in component schedule (room 1 for ex.)
  • The exterior finish should be located by façade number, and since we use the same BM for different elements, located on multiple façades, you can't assign that to properties in the BM itself, this information comes from the element level, a property to devine the façade Number, of the element, and here starts inconsistency :
    you need an element schedule to call all elements by their unique ID : UNIQUE ID ------ Façade N°
    And a component level to match the components ( exterior finish coming from wall 1 exterior , wall 2 exterior , beam, etc ) with the original element
    Element schedule :       UNIQUE ID ------ Façade N°
    Component schedule : UNIQUE ID ( element level )  ------ Material name
    Final result Façade N° ---------- Material name
At the end you may come with missy data, and a lot of table you can''t manage
If the skins could receive properties, that could solve a lot of workarounds ,
The data structure could be like that :
  • Material properties : specifications, thermal Data, material composition etc
  • Skin property :
    • own properties : like relation to zones, Interior facade number....
    • inherited properties : inherited from the parent level : element ID, element storey level,
      The alteration between those levels can be done in the property pet palette
  • Element property : the same we're using now.
Archicad 27
Ahmed_K
Mentor
Does someone faced theese situations before ? Is this workflow common for you guys ?
Archicad 27
mthd
Skin by Skin design was listed on the original roadmap. Is this what is meant by component level design workflows ?
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
Rodger Walsh
Beginner
Expanding component-level workflows is a great step. More flexibility in assigning unique data, renovation tracking, editing things, and visualization for individual skins would enhance design clarity, reduce workarounds, and improve documentation and material takeoffs.
Ahmed_K
Mentor
In the same topic , i think adding classifications and properties to the composite / complex profile skin level is more logical , we can keep classifications and Prop for the BM level for thermic calculations etc ,
for a structured model :
  • the class should be applied to the skin ,
  • Properties are also applied to the skin ,
  • Remove the intersection priority from BM and bring it to the skin Level, why ? to eliminate the need for strong and weak BMs , in 2 composites , the finish can have the same BM , but it's Intersection priority can vary , we can handle intersections easily and locally ,
  • same for renovation status , design options , graphic overrides , they can be assigned to skins not to BMs
Archicad 27
Laurentiu
I think the idea that has been suggested before is a bit more elegant.
Override the intersection priority of the Building Material at the skin level in Composites, but also keep the Intersection Priority at the Building Material level.
I think the intersection priority system is intuitive right now, but this small tweak is enough to give it more flexibility. I don't think the whole system needs to change, the foundation is good imo.
Laurentiu Cauni | Architect | AC 17-28 INT
Windows for AC & iOS for BIMx
