‎2022-10-26
03:07 PM
‎2023-05-24
10:38 AM
Rubia Torres
Hi All,
Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.
To express design intent and extract data at a more detailed level, the component or skin level requires further data and flexibility. We already visualise these skins, have Offset Modifiers for Profiles to create smart parametric extrusions, and Component/Surface Schedules to extract data.
We plan to further develop the component/skin level of elements and expand existing functionality in that area, so we are exploring more about what you need. Some questions:
As we progress in this area, your input will be invaluable to understand priorities and our direction moving forward. Thanks in advance.
‎2024-10-29 10:10 AM
Hi insiders
Can we have an update on this development?
Thanks
‎2025-05-11 10:52 PM
I'm deeply exploring the process of 4d and 5d modelling, and the site quantity survey to track accomplished work.
Component level design will fix alot of workarounds and impossible tasks , like skins by zone, skins by facade, floor finishes by zone, quantity of wall finish by zone faces, and more.
Now, the only way is to model each skin as a separate wall/slab,
‎2025-05-12 12:12 AM - edited ‎2025-05-12 02:41 AM
Exactly. And Graphisoft realized this more than 20 years ago when they had the "Constructor" line of 4d/5d software (later sold) which had to re-model those elements. It would be nice to see fine-grained component/skin/etc control in Archicad itself.
https://mail.aecbytes.com/newsletter/2004/issue_15.html
‎2025-05-14 04:41 PM - edited ‎2025-05-14 04:52 PM
here is a common exemple for me :
wall skins relation to zone is crucial,
when we make takeoffs, and to ensure all is correct, we need to se the relation of an element / component to the related zone,
this will be our starting point for quantity statements onsite, and for tracking site work evolution
Composite Wall 01 start from room 1 to room 2,
it's skins belong sometimes to room 1, sometimes to room 2, and some times to the façade
A small beam under the wall is used to cover the slab edge, it has the same material as the exterior wall finish.
To quantify materials there is a logic :
you can divide the wall , and say, hey this segment is for room 1 and this is for room 2, ok it will work, nut not for too long :
At the end you may come with missy data, and a lot of table you can''t manage
If the skins could receive properties, that could solve a lot of workarounds ,
The data structure could be like that :
‎2025-05-15 06:09 PM
Does someone faced theese situations before ? Is this workflow common for you guys ?
‎2025-05-18 06:14 AM
Skin by Skin design was listed on the original roadmap. Is this what is meant by component level design workflows ?
‎2025-05-20 08:52 PM
Expanding component-level workflows is a great step. More flexibility in assigning unique data, renovation tracking, editing things, and visualization for individual skins would enhance design clarity, reduce workarounds, and improve documentation and material takeoffs.
a week ago
In the same topic , i think adding classifications and properties to the composite / complex profile skin level is more logical , we can keep classifications and Prop for the BM level for thermic calculations etc ,
for a structured model :
a week ago
I think the idea that has been suggested before is a bit more elegant.
Override the intersection priority of the Building Material at the skin level in Composites, but also keep the Intersection Priority at the Building Material level.
I think the intersection priority system is intuitive right now, but this small tweak is enough to give it more flexibility. I don't think the whole system needs to change, the foundation is good imo.
