2026-07-24 03:41 AM - last edited yesterday
Hey everyone!
This is my first post here, and I'd like to kick things off by sharing something I built with AI — a tool I've been missing in Archicad.
You know when you put together a furniture set or a "kit" of objects that keeps repeating across different projects, and there's no native way to save all of them as a reusable favorite? That's exactly the problem this add-on solves.
What it does?
You select a group of objects and/or lamp in plan, give it a name, and save it all as a single favorite!
Afterward, just double-click the favorite and place it wherever you want — with the option to rotate 90° before dropping it (spacebar).
You can replace an already-placed group with another one in the same spot, search by name, rename, move between folders, and even import favorites from someone else in your office.
What gets saved in each favorite isn't just the geometry — it also includes size, parameters, classification, and properties... everything comes along, identical to the original.
The palette is dockable on the side of ArchiCAD, just like the native palettes.
Why I made it?
In my opinion, this is a feature that could easily exist natively in ArchiCAD — saving a favorite made of a set of elements — but since it doesn't, I decided to build the tool myself.
Requirements
Works on ArchiCAD 29 on Windows, with the latest update installed.
Only saves Objects and lamps (other element types in the selection are ignored).
Installation
Open the Options menu > Extension Manager > Add
Look for the "Favorite Groups.apx" file below for download
The palette will appear under a new menu called "RGM"
I also attached a short video of it in action!
Hope it's useful to someone,
Enjoy!
P.S. I can't attach the .apx file directly to the post, so I put it in a Drive folder for download.
Edit 1:
I made an update so that Labels are now also included in the group, keeping the original appearance of the text box and leader lines! Updated file available for download on Drive.
Edit 2:
New version available, capable of saving texts, lines, arcs, polylines, hatches, and dimensions in your favorites group! This version also prevents a crash in some cases where an older object is saved in the group.
Known bug: Avoid rotating the group before inserting it into the floor plan if it contains a dimension, as it is not being rotated along with the rest — this causes a discrepancy in the measured value.
2026-07-24 03:45 AM
That's so cool Allan! Thank yout for sharing. It will be a really time (and life) saver!
It would be very cool if GS could incorporate this feature for all users.
Already voted!
2026-07-24 04:13 AM
Have you ask over on the C++ or Python API sub about drawing walls and other elements.
2026-07-24 04:58 AM
I didn't ask I just need to insert the objects for a project I'm working on right now.
I might consider implementing other elements in the future!
2026-07-24 09:14 AM - edited 2026-07-24 10:49 AM
This is going to be really usefull for grouped furnitures of different rooms. Kitchen furnitures cupboard etc. come to my mind.
In another approach this feels like what has been discussed for so long about "Internal Hotlinks" which exist inside the project and not in external files.
There are great potentials here as It opens a new workflow.
Great work @Allan_Fx !
Link is not working for the wishlist....
2026-07-24 02:20 PM
Thank you, @Botonis!
I'm not sure why, but the wish I created no longer existis, so I made a new one and updated the link.
2026-07-24 03:45 PM
The wishes have been removed because you were not making a wish.
You are promoting an add-on that you have created.
The wish list is for something you would like Graphisoft to consider.
2026-07-24 05:10 PM
Well, that wasn't my goal!
What I made has its limitations, and my wish was for this to become a more robust tool, native to ArchiCAD — allowing more elements to be saved, not just objects.
Either way, the post is here and available for anyone who wants to try it out.
2026-07-25 03:18 AM
The wishes you made were basically the same as you first post in this thread, saying that you had created an add-on already.
Not wishing that Graphisoft could incorporate this into Archicad.
That is why the wishes were removed.
If you want to enhance your add-on to include other elements other than just objects, make a post in the Developer hub C++ API forum asking for help for how to include them, or even if it is possible.
But then I think you would just be re-inventing hotlink modules.
2026-07-25 05:12 AM
Love the potential of this! Would love it to work for numerous element types too, like walls, slabs, annotation even! My brain goes to using this for accessible toilet layouts, including the internal elevation markers. 🤩🤩
2026-07-25 10:18 AM
very good job , i can see this to evolve toward a great new tool in the toolbar , : Group tool , we can assemble for exemple a window with custom jambs , or a set of table + chairs etc
a week ago
I believe that the whole UI of this addon should follow the Favourites Pallete. Pictures, Names Folders, apply method etc.
This can be the absolute replacement of the Favourites Pallete.
Obviously this is in theory as I don't know what are the exact background difficulties to achieve this.
Friday - last edited Friday
Thank you so much!
Friday
Hello! I have two small updates to share.
Update 1
I made some adjustments and added the ability to export selected favorites to a separate .TXT file, making it easier to share between collaborators!
Update 2
Labels are now also included in the group, preserving the original appearance of the text box and leader lines! Updated file available for download on the Drive.
Also, a big thank you to @Zaid Haddad for selecting this post as a "Tip of the Month"! 😀
Monday
Hi Allan! Thanks for sharing the updates! We’ve updated the post with both of these additions.
You can find the updated post here: https://community.graphisoft.com/t5/Graphisoft-Insights/Tip-of-the-Month-group-and-save-reusable-fur...
And thank you as well for sharing your knowledge with the community and for continuing to inspire others with your work! It’s great to see how the tool keeps evolving.
Sunday
Dear Allan, I suddenly had an idea: could your plugin's concept be used to develop a "super group" feature that enhances AC's native group functionality? This would allow for nested groups, where a parent group could be opened to edit the content of its child groups, and then closed again. Of course, I'm not sure if this feature would be useful, but I just feel that AC's built-in group function is too weak.
Sunday
Are you referring to a hybrid hotlink functionality?
Sunday
It's a bit different. Although I've considered similar hybrid hotlink functionality, like components in SketchUp, I consulted with friends who do AC development, and they said that due to the nature of BIM software, we can't simply copy the concepts of components or blocks. Perhaps everyone hopes for a "block" function that is quick and easy to use in the conceptual design phase. But to be honest, I've pretty much given up on that idea.
Sunday
- last edited
yesterday
I think there are some infos need to translate to INT version. 🙂
yesterday
@Funfun Yan Fixed!
Also, a new version is now available, capable of saving texts, lines, arcs, polylines, hatches, and dimensions in your favorites group!
18 hours ago - last edited 18 hours ago
Great!
I just had an idea: could you please differentiate the "folder" and "favorite" preset items with distinct icons in the manager? This way, we can tell whether it's a managed folder or a specific favorite item based on the icon.
