File History/Reords
Sam Pezzimenti
Hi All,
I just wanted to know if there was as specific way of going into a PLN file and seeing the amount of users that have saved in to/over the file?
Call it a catalogued list of sessions, versions, users, times ect,
Obviously this would only work if the person saved over the file but any help in this area would be greatly appreciated.
Cheers
1 REPLY 1
Guru
If you are storing the files on a NAS or access a server using AzureAD or similar, you should be able to look at the file logs. If your on Sharepoint, you can look up the recent file Version History.
Have you looked into using Teamwork?
Ling.
