a month ago
I just got a Logi MX Master 4, which has a pretty excellent "action ring" function that allows for everything in the screenshot (open apps, open folder, macros, keyboard shortcuts, etc), and you can assign an icon to each function. However, the icons are pretty limited, and there aren't really any that feel really suitable to Archicad's tool set. I was able to reproduce all of the icons from Archicad, but there over 3000 of them, and they are not named per function really.
It would be great to either get a mapping of all of the icons so that I can write a python script to rename the icons per function, and then assign them in Logi.
Or is Graphisoft by some change making a Profile for the Logi marketplace?
Either would be amazing!!
a month ago
On a tangent, but the MX Master 4 can do multi key macros now? I got a S2 a long time ago and returned it when I found that I could not recreate my G502 macros on it...
a month ago
Yes, the MX Master 4 can do multi key macros, amongst many other things — it has a lot of the same options that the 3D Connection Space Mouse has in terms of creating compound commands (macros) and more. You can set up and app (I use Rhino also), so that what ever your current app is, the Action Ring calls up all of those app-specific commands. It's pretty great, have to say, just really want to keep the UI icons the same across the app/action ring!
a month ago
You can create custom icons either with text or by dragging and dropping an appropriately sized image. It's been a while since I did that, but I know it's possible.
a month ago
Yes, for sure, you can make any custom icons in Logi Options +, but what I'm trying to do is use Archicad's exact logos so that there's coherence between Options + and Archicad visually, since the name of the command in the Action Ring don't pop up until a second or so later.
