‎2018-02-20
07:38 PM
‎2024-12-30
04:14 PM
Molinda Prey
‎2018-02-21 09:47 AM
‎2018-02-21 01:48 PM
‎2018-02-21 09:23 PM
‎2018-02-22 12:49 AM
‎2018-02-22 07:49 AM
‎2018-02-22 04:01 PM
‎2018-02-22 07:55 PM
poco2013 wrote:I agree with this assessment about CA and SoftPlan. I was once very good with SoftPlan. I was selling and training for a SoftPlan distributor when he gave me an ArchiCAD demo so I could be informed about how to sell against it. I jumped ship immediately and have never regretted it.
You neglected to describe your intended use which makes it difficult to compare products as the ones you mentioned are targeted to different markets. To answer your question directly. I'd rate Archicad as superior to any in the area of construction documents in the arena of ease of use, versatility, time, completeness and accuracy. IOW - all areas.
I've used Archicad since version 17 and Chief for about 10 years now. IMNOHO – CA is just adequate for CD, and mostly for mainstream residential. Completely unacceptable for large commercial and somewhere in between for anything else. I would not use CA for any significant commercial project. CA's use in Residential is really dependent on the documentation required by the builder and the review boards - usually not that difficult and with limited specifications. However, I agree, with respect to Kitchen design and their docs, Chief is competitive with any, including 20/20. Wood framing is very good if you agree with their concept. Somewhat problematic to alter and edit. They create a decent B/M but take a lot of short cuts which would cause problems within a commercial contract. Data access is limited and little or no BIM which makes it more difficult to work with trades.
I had access to SoftPlan for about 6 months and found it comparable to CA but offers no real advantage and is not as intuitive. Gave up on it.
Archicad is not a Kitchen design program and is only just adequate there. A nightmare in the area of wood framing and interior design. It takes quite a bit of time (comparatively), forethought and preparation in these areas but there are things you can do in AC that you can not do in residential targeted programs. IOW, Archicad is quite complete, but requires quite a lot of user preparation. Most AC users have a long history and a fairly extensively prepared custom user library and preferences. It has a number of tools that makes a complex design straight forward without workarounds but all require time and expertise. My point is that there is a lot more to consider overall than just Con Docs.
Not knowing your requirements, but I agree and would strongly recommend that you put Vectorworks on your list?
‎2018-02-22 09:20 PM
‎2018-02-22 10:25 PM
Steve wrote:Everyone is entitled but I disagree (mostly) that it's a matter of skill here. More a matter of familiarity and experience with the programs. Or the degree of training required in comparison. The view posted can be done with a few clicks in residential programs with a complete listing and summaries of all elements without resorting to objects and/or property programing, and without too much training - not impressed if that was you point as i am aware of the effort & time to produce the same in Archicad vs other programs. Same with Kitchens. It's not a matter of "can it be done" but the effort.
I think this is a matter of skill with the program not it's functionality.
‎2018-02-22 10:32 PM
‎2018-02-23 05:52 AM
poco2013 wrote:I think Jackreese108 would need many hours of training for each of those program demos to even know how to compare them. I could be wrong, but I think he is just beginning to explore what making Construction Documents is all about.Steve wrote:Everyone is entitled but I disagree (mostly) that it's a matter of skill here. More a matter of familiarity and experience with the programs. Or the degree of training required in comparison. The view posted can be done with a few clicks in residential programs with a complete listing and summaries of all elements without resorting to objects and/or property programing, and without too much training - not impressed if that was you point as i am aware of the effort & time to produce the same in Archicad vs other programs. Same with Kitchens. It's not a matter of "can it be done" but the effort.
I strongly suggest that the poster obtain a demo of Archicad and make the direct comparisons himself.
‎2018-02-23 08:25 AM
Steve wrote:I know exactly what they are, I do occasionally need to refer to them for my work. Yet, I have never created them and so in that sense I am new to this. I suspect you are making your assumption because of my particular definition of quality when content is the most important aspect. Having all the necessary details in the docs is the priority I realize. But that aspect is a matter of my "capturing" that data in the layout phase and does not have much to do with the software as it will present
Jackreese108
From reading a few of your posts, I suspect that you may not really understand what Construction Documents even are.
Steve wrote:As I mentioned I do residential building, and have no need for collaboration.
And what kind of buildings would you want to make plans for? Will you have any need to collaborate with others... that sort of thing.
Steve wrote:Thanks very much Steve, I appreciate your encouragement and support.
Whatever the case may be, you are in the right place. There are ArchiCAD users here at every skill level and construction experience, making plans for every kind of building large or small. And plenty of them that will enjoy helping you along the way from where ever you are at now.
‎2018-02-23 12:53 PM
Steve wrote:Good Advice!!
For all I know, you are just not aware that ArchiCAD can do things very well witch you think other programs can do better.
And how would Jack know that? He doesn't. It's all subjective opinion if one program is better for someone than for someone else.
‎2018-02-23 01:50 PM
Steve wrote:Well, not me. I've been using Revit for 4 years before moving to Archicad, and I continue to use it occasionally (and teach it as well). Revit has a lot of qualities but it's (really really) heavy to use and specially to produce and manage construction documents.
For someone just starting out, I would recommend Revit. I don't like using Revit at all, but by the time they have 10 years experience with Revit it is likely to be a better choice than ArchiCAD. I base that very sad opinion on what I think Revit is becoming vs what I think ArchiCAD is becoming.
In ten years, I don't plan to care anymore.
‎2018-02-23 05:21 PM
Jackreese108 wrote:The documents that may be appearing "cramped and fuzzy" are certainly not Chief Architect's fault. You have total control over placement, size, lineweights, fonts, etc. Bad-looking construction documents are undoubtedly due to the inexperience of the drafter. There are some sample construction drawings in PDF format on the Chief Architect website in the "Samples Gallery," so you can see for yourself. There is an _okay_ 2D toolset in Chief, although AC's is better. You can certainly create anything you want in Sketchup and simply drag it into Chief Architect, as you sort of can in ArchiCAD, although with AC's morph tool, you don't have to.
I've been looking hard at Chief Architect, downloaded trial and reading forums and tutorials. Here is my sense of CA at this point, and I'm hoping Richard and anyone else with experience can tell me if my assessment is accurate or not. CA is a very fast and easy way to model a relatively simple residential design, and from there it has a streamlined process of creating con docs from that design. But what I'm hearing, and have seen of an actual doc shown on youtube is that the docs do not look good at all, cramped and fuzzy. Maybe CA does not have the 2d toolset to spruce up the docs and improve the layout and readability? Or maybe it is the users lack of deeper knowledge and skill with the software?
The other limitation about CA I'm seeing is that it does not have the flexibility of a Sketchup type modeler. I can build a home in sketchup (fairly quickly) with every stud and sheet of drywall built up. Not that I would need to do that, but I would like to have that functionality. I know I said we do simple construction around here, but I'd like to potentially branch out into more unconventional designs. Does CA have that design flexibility?
‎2018-02-24 09:42 AM
‎2018-02-24 04:57 PM
Jackreese108 wrote:A full version of AC will be _significantly_ more. (Think $5000 +) There is a rental option, as well, I believe. ArchiCAD Solo is an option at less cost, but then you won't get the Cinerender engine included. Maybe this information simplifies your choices.
And checking the price of vectorworks at 3000 (AC is probably similar)
‎2018-02-24 07:06 PM
‎2018-02-28 04:51 AM
felcunha wrote:ArchiCAD is the better program. Sadly, that is very seldom the most critical factor in selecting a software program to build your career around. I love using ArchiCAD because I just a little one man show and I don't need to collaborate with other BIM software programs. ArchiCAD has everything I need , and then some. But not everyone can work as independently as I do.Steve wrote:Well, not me. I've been using Revit for 4 years before moving to Archicad, and I continue to use it occasionally (and teach it as well). Revit has a lot of qualities but it's (really really) heavy to use and specially to produce and manage construction documents.
For people dealing with architecture more than with structure and MEP, and wanting to be designers and not software experts, I recommend Archicad over Revit. A thousand times.
‎2018-02-28 07:15 AM
Richard wrote:Thanks Richard, but I don't think there is any program that can model the framing in that building in a matter of seconds. Some parts of it of course, but most of it almost... but not quite. There is no magic button that will Frame the building exactly like you need it and for all the all the reasons you need to have it a certain way. All things considered, I like ArchiCAD for what I am doing. But the new user should understand that if they want a career working as an employee, (what an unfortunate thing) they should learn to use Revit because they will have 100x more job opportunities.
The framing model that Steve showed would take about 30 sec's to create in Chief, and you'd get a full list of materials. However, Steve does some of the nicest and most complete residential construction doc's I've ever seen, so maybe you could get him to show you a sample of what an advanced AC user can do.
