General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
Looking for an objective opinion as to how well Archicad does construction documents
I'm looking for a long term software solution that does the best job with making construction documents. I've been playing with Sketchup and Rhino but feel that the process for turning the model into condocs is clunky.
Other contending software that I'm looking at are:
Revit
Chief Architect
Softplan
If anyone has experience with any of those for condocs please let me know your thoughts.
Thanks.
25 REPLIES 25
Tim Ball
I use AC to create a complete 3D model of my building including all the specification information. From that model I can then extract all the plans, elevations, sections, 3D details I need and place them on layouts as drawings. Those drawings are then published to PDF or any other format you need.
I can also extract the specification and most simple quantities.
The same model is used to create a BIMX file that includes 3D, drawings and specification embedded in the 3D elements.
Now this is a pretty advanced way of working, but is increasingly common amongst other users. I don’t know the capability of the other programmes but you could check and see what they can do as well.
I recommend talking to users not the software companies as users have true knowledge of what works and makes you money.
I am doing a webinar about this through LearnVirtual on 1st March. You can find their website and take a look if you are interested.
Tim Ball
AC26, iMac
User since V5
gpowless
I have been using ARCHICAD since V.6. Before I purchased ARCHICAD 6.0 I explored and tested Chief Architect and Softplan and have re-evaluated both on and off through the last 18 years.
Chief Architect is quick to learn and use at a rudimentary level. I have found that to do anything creative beyond 4 walls is increasingly difficult. The final construction drawings it produces seem to me to be simple and inaccurate. I wouldn't recommend it.
Softplan is a little more robust. I think its niche is limited to mainly small home designs. The last time I tested it I found that I had to try to defeat some of its common tool behavior to get it to do what I wanted. That could have been my inexperience but it turned me off completely. The output produces reasonable accurate contruction drawings. A collegue of mine used it for a couple of years but always had complaints about non-standard roof creation. He ultimately turned back to AutoCad to increase his efficiency and accuracy.
For small buildings (under 6000 sq ft) I think SoftPlan goes head to head with Revit or Archicad but for larger buildings I have my doubts.
When I first started my practice ARCHICAD had everything I was looking for. At the time it was pricey. One had to purchase the full version without the options we have today. But I was producing decent construction drawings within 2 weeks.
To me it was like Microsoft Word. You can type a letter right away without having to learn many of its feature. But as you gain experience the features built in reduce the time & repetitiveness of operations. With ARCHICAD one can produce complete 3D construction drawings from sheds to complex tall buildings.
The rendering and presentation of design results are far superior to anything I have seen from SoftPlan or Revit. The depth of modelling is flexible and I don't need to use any post-processing software for final models. Many of my designs require countless details and I am always able to convey the design and construction materials and methods to the owners, building offiials and contractors without having to clarify over and over again.
I have rejected Revit over time as a viable platform because 1. it was in its infancy and was suffering from many backward compatible issues and 2. because it is still stuck on being a child of AutoCad which has its roots on repeating drafting board methods and 2D line drawing. I understand Revit has grown up a bit but I'm not convinced enough to move away from something I have been comfortable for 18 years.
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
I have used both ArchiCAD and Chief Architect for roughly 20 years each. I'm afraid I have to disagree with gpowless about Chief Architect. If you are doing primarily mainstream residential, especially in the U.S., it has gotten very powerful and is quite impressive. There is little reason to think it is inaccurate, and it has features like cabinets and framing that far exceed what ArchiCAD is capable of at the moment. You should watch the video on their website, and give it a spin. However, if you are doing things like canted walls, highly intricate details, commercial/large projects, renovations, and/or especially working with other people on the same project, you will be happier with ArchiCAD.
Revit: I can't stand the interface or the company that produces it, so nothing good to say there. But I have colleagues who seem to like it. (Although very few people who also have spent time with ArchiCAD seem to prefer Revit.)
Softplan: For residential, it does very nice drawings, but pretty mainstream production quality. When I evaluated last, it required many files to consolidate into a single project, so seemed heavy on file management, but that may have changed.
I'm surprised that you aren't including Vectorworks in your evaluation mix. From a purely condoc perspective, I think it does some of the nicest 2D drawings I've seen.
Richard
AC26 (since AC6.0), Win10
poco2013
Mentor
You neglected to describe your intended use which makes it difficult to compare products as the ones you mentioned are targeted to different markets. To answer your question directly. I'd rate Archicad as superior to any in the area of construction documents in the arena of ease of use, versatility, time, completeness and accuracy. IOW - all areas.
I've used Archicad since version 17 and Chief for about 10 years now. IMNOHO – CA is just adequate for CD, and mostly for mainstream residential. Completely unacceptable for large commercial and somewhere in between for anything else. I would not use CA for any significant commercial project. CA's use in Residential is really dependent on the documentation required by the builder and the review boards - usually not that difficult and with limited specifications. However, I agree, with respect to Kitchen design and their docs, Chief is competitive with any, including 20/20. Wood framing is very good if you agree with their concept. Somewhat problematic to alter and edit. They create a decent B/M but take a lot of short cuts which would cause problems within a commercial contract. Data access is limited and little or no BIM which makes it more difficult to work with trades.
I had access to SoftPlan for about 6 months and found it comparable to CA but offers no real advantage and is not as intuitive. Gave up on it.
Archicad is not a Kitchen design program and is only just adequate there. A nightmare in the area of wood framing and interior design. It takes quite a bit of time (comparatively), forethought and preparation in these areas but there are things you can do in AC that you can not do in residential targeted programs. IOW, Archicad is quite complete, but requires quite a lot of user preparation. Most AC users have a long history and a fairly extensively prepared custom user library and preferences. It has a number of tools that makes a complex design straight forward without workarounds but all require time and expertise. My point is that there is a lot more to consider overall than just Con Docs.
Not knowing your requirements, but I agree and would strongly recommend that you put Vectorworks on your list?
Gerry
Thanks all.
I will put vectorworks on my list and check it out.
Yes, I should have given some details about my intended use. I'm not an architect, I'm a general contractor in northern california, in a somewhat rural area. Most of the residential buildings here are pretty simple. There is not much work for architects here, most of the building is done by contractors and engineers. I've been sub-contracting with another GC that has been building houses for decades in this area (and down to the bay area) and I'm working on my own design and just learning the process of making construction docs for permit approval. I feel there is a little niche side market here for producing CD's for other builders and engineers, as there are not many services for this here. The guy I work with has been doing his by hand with pencil and ruler, if you can believe that. and the person he has just starting using is a woman who is a graphic artist and she does the CDs in Adobe Illustrator, which is basically doing it by hand but with graphics software, (her work comes out really great looking and professional), but he has to feed her every little detail, and it takes her a while.
Anyway, I'm feeling compelled to really learn the design end of construction for a couple of reasons. One, I'm finding the artistic aspect of home design very interesting and rewarding, and two, I feel like I can provide a service for other builders by turning there design ideas into a 3d model and from there producing complete CDs for them.
I'm pretty proficient with Sketchup (not much of a learning curve) and have been trying to use Layout to make CD's of my design but the process feels a bit wonky, but maybe it is as good as it gets, I have nothing to compare it to.
So, that is why I say I'm looking for a software that is really good at producing complete detailed, professional, and pretty šŸ˜‰ CDs. Though I realize that the modeling of the design is an integral part of the process.
I've been noticing the connection on this forum of Rhino+Grasshopper+Archicad and wondering if that is a good option for taking a Rhino model and exporting to AC for the CD phase? I have some experience with Rhino with non-architectural modeling and really like it, very flexible and powerful, much more so that Sketchup from what I can tell.
Then, based on what you've just said, Chief Architect should be your program.
Richard
Steve Jepson
I agree with this assessment about CA and SoftPlan. I was once very good with SoftPlan. I was selling and training for a SoftPlan distributor when he gave me an ArchiCAD demo so I could be informed about how to sell against it. I jumped ship immediately and have never regretted it.
I do not agree at all about any lack of ability with ArchiCAD in producing casework/kitchen cabinet plans and shop drawings. It's not 20/20, but it doesn't need to be. And I really like what I can do with ArchiCAD to produce framing plans, models, diagrams, layouts, schedules... I think this is a matter of skill with the program not it's functionality.
In thinking about it more I would say that I have two main requirements of the software package. First and foremost I want to be able to produce Con Docs of the quality that the graphic artist I mentioned does, and do that in much less time than it takes her. Her docs are high end. Beautiful color rendering, and color use for distinguishing things like hot and cold water lines, topo maps etc. It's not just that it is pretty, it is very well laid out and very readable. When you submit plans to the county they'll tell you expect to wait 2-3 months for permit, but the guy I work with says the last couple plans he submitted of her docs the turnaround was only 1 month and he believes it is because of the quality of the docs. If they are very clear, readable, and discernible it makes a difference in the time it takes for the county to approve them, and that is very important to me. Obviously I'm not going to learn to make docs in Illustrator. And maybe there is no arch software that can match that quality, but if there is I want to learn it and am willing to put in the time to really learn it even if it is complex.
I've been looking hard at Chief Architect, downloaded trial and reading forums and tutorials. Here is my sense of CA at this point, and I'm hoping Richard and anyone else with experience can tell me if my assessment is accurate or not. CA is a very fast and easy way to model a relatively simple residential design, and from there it has a streamlined process of creating con docs from that design. But what I'm hearing, and have seen of an actual doc shown on youtube is that the docs do not look good at all, cramped and fuzzy. Maybe CA does not have the 2d toolset to spruce up the docs and improve the layout and readability? Or maybe it is the users lack of deeper knowledge and skill with the software?
The other limitation about CA I'm seeing is that it does not have the flexibility of a Sketchup type modeler. I can build a home in sketchup (fairly quickly) with every stud and sheet of drywall built up. Not that I would need to do that, but I would like to have that functionality. I know I said we do simple construction around here, but I'd like to potentially branch out into more unconventional designs. Does CA have that design flexibility?
I would really like to know if Archicad would meet the requirements that I mentioned. I'm sure it does a lot more that my simple needs, but does it really do the two things I require well?
And I'm wondering further if the best path would be to use Rhino for the design and then export to something like maybe Vectorworks or Archicad for the con docs. Anyone have a sense about that? Maybe that is a question for the Rhino forums.
poco2013
Mentor
Everyone is entitled but I disagree (mostly) that it's a matter of skill here. More a matter of familiarity and experience with the programs. Or the degree of training required in comparison. The view posted can be done with a few clicks in residential programs with a complete listing and summaries of all elements without resorting to objects and/or property programing, and without too much training - not impressed if that was you point as i am aware of the effort & time to produce the same in Archicad vs other programs. Same with Kitchens. It's not a matter of "can it be done" but the effort.
I strongly suggest that the poster obtain a demo of Archicad and make the direct comparisons himself.
Gerry
Steve Jepson
Jackreese108
From reading a few of your posts, I suspect that you may not really understand what Construction Documents even are. Have you ever made working drawings for a building? Or is this just something you would like to start doing, and this is why you want to choose a CAD program carefully, making sure it can do what you imagine you would want to do with it.
This is important to understand if we are to give you any useful advice. And what kind of buildings would you want to make plans for? Will you have any need to collaborate with others... that sort of thing.
Whatever the case may be, you are in the right place. There are ArchiCAD users here at every skill level and construction experience, making plans for every kind of building large or small. And plenty of them that will enjoy helping you along the way from where ever you are at now.
Steve Jepson
I think Jackreese108 would need many hours of training for each of those program demos to even know how to compare them. I could be wrong, but I think he is just beginning to explore what making Construction Documents is all about.
I am not posting the picture to impress anyone, I am posting a picture I had quick access to as an example for Jackreese108, to show him that ArchiCAD has the potential to be as good as any program for making framing models, framing plans, framing diagrams, schedules...
"without resorting to objects and/or property programing, and without too much training" ??
The model shown is entirely regular ArchiCAD elements. Columns, beams, roofs, slabs, walls, complex profiles, standard library parts, a little SEO, not even any accessory tools. And it is unique enough in so many ways that there is no "residential program" that can do what I am doing with ArchiCAD in "a couple of clicks" . This isn't all being done primarily for the sake of a materials list either, as it would be with some of the other programs. It's being modeled for more uses than I care to list. Things that are not even possible in programs like CA and SP which are not BIM software.
".... i am aware of the effort & time to produce the same in ArchiCad vs other programs...."
Are you? Or are you just unaware of how to do it better in ArchiCAD ?
"Same with Kitchens. It's not a matter of "can it be done" but the effort."
The effort for who? You, Me, Jack...?
For all I know, you are just not aware that ArchiCAD can do things very well witch you think other programs can do better.
And how would Jack know that? He doesn't. It's all subjective opinion if one program is better for someone than for someone else.
For myself I still choose ArchiCAD and I am free to use any program I want. In two or three years time I am sure I could be very good at using any of them.
For someone just starting out, I would recommend Revit. I don't like using Revit at all, but by the time they have 10 years experience with Revit it is likely to be a better choice than ArchiCAD. I base that very sad opinion on what I think Revit is becoming vs what I think ArchiCAD is becoming.
In ten years, I don't plan to care anymore.
Steve wrote:
Jackreese108
I know exactly what they are, I do occasionally need to refer to them for my work. Yet, I have never created them and so in that sense I am new to this. I suspect you are making your assumption because of my particular definition of quality when content is the most important aspect. Having all the necessary details in the docs is the priority I realize. But that aspect is a matter of my "capturing" that data in the layout phase and does not have much to do with the software as it will present what I give it, but how it is presented is a matter of the software. Maybe I am missing something here.
As I mentioned I do residential building, and have no need for collaboration.
Thanks very much Steve, I appreciate your encouragement and support.
Jack
poco2013
Mentor
Good Advice!!
Which the poster will find out if he cares to actually demo the software. But I also agree that a 30 day Demo is insufficient to get a feel of a program's productivity. Best path is to spend several weeks viewing training materials and perhaps Youtube videos before starting the demo period. i would also suggest that you just don't select the videos randomly but try to target them to the type of projects and specific work you just completed. As in, how would I do the same thing in: Also it would be worth while to enroll in some of the training classes offered for the 'final cut' software considered. Rather expensive to do, but worth it in the long run. Finally -- just take a project, as the one displayed, and work it in the demos to find out how you would do the same in each.
IOW: That's why all of us are suggesting "you look before---": Talk mainly to those who have actually completed the same type projects in both sets of software. Forums are not a good place to do this as you will only see mostly bias. Good Luck!!
Gerry
felcunha
Well, not me. I've been using Revit for 4 years before moving to Archicad, and I continue to use it occasionally (and teach it as well). Revit has a lot of qualities but it's (really really) heavy to use and specially to produce and manage construction documents.
For people dealing with architecture more than with structure and MEP, and wanting to be designers and not software experts, I recommend Archicad over Revit. A thousand times.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
The documents that may be appearing "cramped and fuzzy" are certainly not Chief Architect's fault. You have total control over placement, size, lineweights, fonts, etc. Bad-looking construction documents are undoubtedly due to the inexperience of the drafter. There are some sample construction drawings in PDF format on the Chief Architect website in the "Samples Gallery," so you can see for yourself. There is an _okay_ 2D toolset in Chief, although AC's is better. You can certainly create anything you want in Sketchup and simply drag it into Chief Architect, as you sort of can in ArchiCAD, although with AC's morph tool, you don't have to.
The framing model that Steve showed would take about 30 sec's to create in Chief, and you'd get a full list of materials. However, Steve does some of the nicest and most complete residential construction doc's I've ever seen, so maybe you could get him to show you a sample of what an advanced AC user can do.
The artistic qualities that can be achieved in 2D construction docs are probably higher in AC than CA, and even higher in Vectorworks. The time you put into this end can be very self-satisfying for someone who truly appreciates it, but it makes for a very poor business model.
Richard
Thanks Richard,
I'm going to finish this project with sketchup/layout as I need to get it done and don't have time to learn anything else right now. But when I'm done I'm going to try and do the same project in CA and see how it compares. I like the idea of Archicad and Vectorworks (hate the idea of revit - marketing-centric software) but those programs might be a little overkill for me right now. And checking the price of vectorworks at 3000 (AC is probably similar) that is a bit more than I'm willing to spend at this stage in the game.
A full version of AC will be _significantly_ more. (Think $5000 +) There is a rental option, as well, I believe. ArchiCAD Solo is an option at less cost, but then you won't get the Cinerender engine included. Maybe this information simplifies your choices.
Richard
Adding to Richard's post on pricing... ARCHICAD 21 Solo lists for USD 2,995 and 21 Professional (Full) is 5,495. As a solo practitioner, the Solo product is probably sufficient for your described needs - unless you need/want the Cinerender rendering functionality as Richard mentions. Scroll down here for prices for permanent license ... as well as short term rentals. (Your geographic reseller may be different.)
https://bim6x.com/store
Some info on file compatibility between versions is here:
https://helpcenter.graphisoft.com/technotes/licensing/archicad-license-types/
Feature differences:
http://www.graphisoft.com/archicad/solo-edition/
Finally - a 2 year old blog post by Jared Banks gives an experienced user's perspective on Solo (which replaced the more limited START edition). Keep in mind that Solo 21 has more features than are described here:
http://www.shoegnome.com/2016/03/27/archicad-solo-has-limitations-and-thats-great/
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Steve Jepson
ArchiCAD is the better program. Sadly, that is very seldom the most critical factor in selecting a software program to build your career around. I love using ArchiCAD because I just a little one man show and I don't need to collaborate with other BIM software programs. ArchiCAD has everything I need , and then some. But not everyone can work as independently as I do.
Steve Jepson
Thanks Richard, but I don't think there is any program that can model the framing in that building in a matter of seconds. Some parts of it of course, but most of it almost... but not quite. There is no magic button that will Frame the building exactly like you need it and for all the all the reasons you need to have it a certain way. All things considered, I like ArchiCAD for what I am doing. But the new user should understand that if they want a career working as an employee, (what an unfortunate thing) they should learn to use Revit because they will have 100x more job opportunities.
