Virtual Tutor 10 - Reviews
Hello people!
Has anyone bought VT10 maybe?
I saw that its available, but didnt find any reviews so far...
Opinions, suggestions...
Thank you
7 Replies 7
TomWaltz
It's kind of the same as the one for AC9.
It's a bunch of videos on AC10 usage. It's a lot of information, but gets a bit monotonous after a while.
Tom Waltz
What do you mean Tom , not good?
You think they did a better job with VT9 then with VT10?
KeesW
I've used VT10 and can't speak highly enough of it. It is monotonous if you go through it from start to finish but I don't think that is how it is meant to be used. It is a resource that you dip into when you need it. It thoroughly covers most Archicad commands and will show you how they are used.
When one starts out with ArchiCad, attending a training course is probably best but VT10 can then be used as a refresher. If you don't have access to training courses, it can be used as a supplement to the tutorials and training excercises that come with ArchiCad.
I've been using AC for nearly 10 years and still find lots of useful stuff in VT10. Try it - its not expensive for the benefits you get out of it.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
Thanx for the tips KeesW:-)
Does anybody knows any direct online store in USA, other then objectsonline?
http://www.cadgarage.com/nevituforar1.html
TomWaltz
I had the same problem with VT9: lots of information, but very boring to watch.
Tom Waltz
Thanx BAS!
Come on Michael
If you know everthing, any you are an AC masetr, then I can understand you compleatly, otherwise...
