4 hours ago
Hi All, I have downloaded AC28 recently, and I found that my Gravity icon is missing in the Toolbar. I have tried to customize the toolbar yet I cant search for the Gravity feature tho. I have launched the AC27 and the Gravity icon is there, but not in AC28 :'(
Can anyone assist me on this?
Thank you in advanced.
Solved! Go to Solution.
3 hours ago
I don't have 28 installed on this machine to check, but are you sure they are not in 'All commands'?
Also if you activate the 'Coordinates' palette, is the gravity too there?
It is in 27 and i assume it would be in 28.
It is still mentioned in the help files, so it should be there.
3 hours ago
3 hours ago
Hi Barry,
Thank you so much for your reply and the attached image! I finally figured it out after searching everywhere. Thanks again 🙂
Sincerely,
Sharon.
