Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Graphisoft Technology Preview Program 2024
BUG: Default Zoom for Schedules
iggiv
This issue was present in AC27 and continues to appear in AC28. When opening a SCHEDULE, the zoom is set to 300% by default once the file is open. While working, I can change it to 100%, but it reverts to 300% when I reopen the file.
Hi Barry,
Yes, I mean zooming of 1:50 & 1:100.
For me it's reset also when I close the file, but if I set the schedule zoom to 1:100 & saved it as a view it's opened as set whatever happened.
AC 27 INT 5030/WIN 11
7 REPLIES 7
Olivier-IDAO
I agree with you, it's annoying, the registered view don't keep the zoom when reopening the file.
I think the default zoom depends on the size and resolution of your screen, for me it's always 150%...
It would be good if the zoom could be saved in the view.
Interior designer, Former & Bim expert
Archicad 6.5 to 27 now
MacStudio 2023 Apple M2 Max powered by MacOS Sonoma 14.5
iggiv
That will be even better if they add it to the view settings. Hopefully, we will have that option soon.
I can open the schedule & the zoom appears to be set to 1/150 but if I change it to 1/100 and saved the view, then it'll be opened via the view map at the newly set scale 1/100, kindly try it.
I am sure you mean zoom of 150% and 100% not 1/150 and 1/100.
For me it stays to what ever I set it to if I close and re-open that schedule.
They may reset when I close the file, I haven't checked that.
But I am pretty sure they stay as set because all of my schedules seem to have different zoom factors when i open them , so there seems to be no default.
iggiv
For me, the default is set to 300%. I thought it might have to do with using an Apple Display and not the Apple Book screen. I disconnected the screen and opened the file on the laptop, but the issue persists.
This is a wish list item, but for some reason, I would prefer to see the size of the schedule at 100%. Once I change it, it stays at the new zoom value, but as soon as I save and reopen the file, all of them go back to 300%.
I think I might be doing something wrong.
When I open a new file using the AC28 template, all of the values are set to 150% and not 300%. I suspect it is my mistake since only one of the schedules in my template is set to 100% while all the others are at 300%.
I will continue playing to see if I can find the cause and will report if I solve it.
Hi Barry,
iggiv
I finally fir the zoom issue manually. I had to open each schedule change the zoom scale then save it with the same name. It created a duplicate schedule ending in 1 which I then deleted after deleting all of the previous schedules. I time consuming but I am glad with the result.
