a week ago
This issue was present in AC27 and continues to appear in AC28. When opening a SCHEDULE, the zoom is set to 300% by default once the file is open. While working, I can change it to 100%, but it reverts to 300% when I reopen the file.
Solved! Go to Solution.
Tuesday
Hi Barry,
Yes, I mean zooming of 1:50 & 1:100.
For me it's reset also when I close the file, but if I set the schedule zoom to 1:100 & saved it as a view it's opened as set whatever happened.
a week ago
I agree with you, it's annoying, the registered view don't keep the zoom when reopening the file.
I think the default zoom depends on the size and resolution of your screen, for me it's always 150%...
It would be good if the zoom could be saved in the view.
a week ago
That will be even better if they add it to the view settings. Hopefully, we will have that option soon.
a week ago
I can open the schedule & the zoom appears to be set to 1/150 but if I change it to 1/100 and saved the view, then it'll be opened via the view map at the newly set scale 1/100, kindly try it.
a week ago
I am sure you mean zoom of 150% and 100% not 1/150 and 1/100.
For me it stays to what ever I set it to if I close and re-open that schedule.
They may reset when I close the file, I haven't checked that.
But I am pretty sure they stay as set because all of my schedules seem to have different zoom factors when i open them , so there seems to be no default.
Tuesday
For me, the default is set to 300%. I thought it might have to do with using an Apple Display and not the Apple Book screen. I disconnected the screen and opened the file on the laptop, but the issue persists.
This is a wish list item, but for some reason, I would prefer to see the size of the schedule at 100%. Once I change it, it stays at the new zoom value, but as soon as I save and reopen the file, all of them go back to 300%.
I think I might be doing something wrong.
When I open a new file using the AC28 template, all of the values are set to 150% and not 300%. I suspect it is my mistake since only one of the schedules in my template is set to 100% while all the others are at 300%.
I will continue playing to see if I can find the cause and will report if I solve it.
Tuesday
Hi Barry,
11 hours ago
I finally fir the zoom issue manually. I had to open each schedule change the zoom scale then save it with the same name. It created a duplicate schedule ending in 1 which I then deleted after deleting all of the previous schedules. I time consuming but I am glad with the result.
