2024-07-09 10:10 PM - edited 2024-07-10 07:51 AM
Dear Graphisoft,
While testing AC28 I switched manually into Dark Mode (that is how I work normally in AC27 INT/POL).
On 27 there were no issues - On 28 INT on the other hand, when turning on "Dark Mode", all letters in Navigator are gone. Icons are also not rendering into "Dark Mode" ones.
Best
Karol
2024-07-10 05:39 AM
Just confirming we're also seeing this when turning dark mode on. We're running M2 Max MacStudios in Sonoma OS14. Also tested it on an intel iMac running Ventura OS13 which has the same issues. Darkmode in AC27 works just fine on both computers.
Other windows with folder structures also have the same issue, e.g. Favourites, Library Manager, Work Environment any of the Attribute windows.
2024-07-10 10:47 AM
OMG..... for years, it's still the same annoyance...
When will this be fixed finally??
It is on the Roadmap, as I remember...
2024-07-10 02:53 PM
This was raised in the beta version and we were informed that it would be fixed in the Technology Preview but alas that doesn't appear to be the case 😞
2024-07-12 10:44 AM
Hi Everyone,
Thank you all for reporting this issue throughout the Beta reporting system. We are planning to fix this issue in the Archicad 28 Technology Preview Update.
Sorry for the inconveniences.
Regards,
Gabor
a month ago - last edited a month ago by Barry Kelly
Attached are screen shots of the same menu area in Archicad 27 and Archicad 28. The field area in Archicad 28 is white and doesn't let you see the text unless you click on it. Otherwise, it looks as expected.
Edit: this post merged from another thread.
