Graphisoft Technology Preview Program 2024
MEP Schedule in ArchiCAD 28
aryani_puspita
How do you bring up the MEP schedule in Archicad 28? I have already used the library part parameter, but it still doesn't show up when I want to find its length,
Thanks
ShineJoseph
This is from my experience. There might be better workarounds.
Within the element schedule use specific component directly. Especialt segments. Not routes.
You may refer to the image below @aryani_puspita
ShineJoseph
Thank you very much, this solution works for me. I have also tried the same way to calculate the pipes and the method works as well.
ShineJoseph
Happy to help
