Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
4K Monitor default line is very narrow
Norbi55555
 Hi, I just bought a 4K monitor and when I turn off real line weight (valós tollvastagság) all the lines became 1pixel wide which is really hard to see. Is there an option to change it to 2-4pixel wide? It was fine on the old Fhd monitor because it’s 4times bigger than on the 4K one.
1 REPLY 1
Erwin Edel
Not sure if it will make a huge difference, but try looking at the 2D alias options.
Options > Work Environment > Advanced Rewdraw Options
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
