Hey all, my AC21 is very fuzzy visually and has some other visual anomalies. I can have 16, 19, and/or 20 running and switch back and forth for comparison, and it's only 21 that's an issue. (16/19/20 are all crystal clear, no problems.)
It's mostly the mouse icons that are the problem. I've attached a screenshot-- it's almost like there are visible nodes  in the mercedes and the arrow.
The lines all tend to distort as well-- there's no consistency to the lineweight on screen no matter what the pen, element, or fill pattern is.
Another issue which may or may not be related is that any text that is not left-aligned skews way off to the right on-screen. It does print fine but falls largely outside of the text box on-screen. (You can see this in the 21 screen shot too.)
Any thoughts on how to fix this/these??
In case it matters-- running a ~6 month old Dell Precision 7510 laptop with dual monitors, Nvidia Quadro M2000M v376.54, Intel Xeon 3ghz, 64-bit, with Windows 7 Pro+SP1.
