Showing results forย
Search instead forย
Did you mean:ย
Search instead forย
Did you mean:ย
rm
AC doors and windows disappearing
Using AC 8.1 doors or windows has been very frustrating. When adjusting them, stretching, changing parameters in plan, I find them disappearing on screen even in plan after rebuilding or refreshing the screen. Yet they show up in 3D just fine.
My work-a-round ( which is a complete waste of time ) is that I have to close the file, then restart the file, and then the parts show up as expected again.
Is anyone else experiencing this?
Is this a know bug?
Is there an updated AC 8.1 Library that I should be using?
BTW, I'm using AC 8.1 on OSX 10.3.3 on a G4 with 1.5 megs of RAM.
Thanks,
Robert Mariani
Robert Mariani
MARIANI design studio, PLLC
Architecture / Architectural Photography
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
12 Replies 12
Dave Jochum
Yes--though the window doesn't completely disappear in plan--just various elements, like sills, or when viewing actual line weights, parts will show incorrectly. It's most definitely a bug, and one I had not encountered before 8.1. In fact, I first noticed it just a few days ago.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GBโ€ขOS 15.6.1โ€ขAC 29 Silicon (latest build)
rm
Thanks Dave for confirming this. If you are experiencing the same problem, I would encourage you to let Tech Support know about it. When I talked to them about it today, they indicated that had not seen this before.
I wonder if this is unique to the MAC side of the AC.
Regards,
Architects Design Forum, Ltd.
Robert Mariani
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
Dave Jochum
Wouldn't be the first time...
Dave Jochum
Djordje
Are you using SEOs on the walls where the doors and windows misbehave?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Dave Jochum
Not in the most recent occurrence. I'll have to go back and check the previous one. Is that a relationship you've found to exist?
Dave Jochum
Dave Jochum
I've checked, and no SEOs are involved.
Dave Jochum
rm
SEO? I'm afraid I have not seen SEO before, what do you mean.
RM
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
Dave Jochum
Solid Element Operations. Djordje was suggesting that the problem might be tied to its use, but not the case in my experience.
Dave Jochum
rm
Thank you Dave on the SEO explanation. In my case, I am NOT using SEO's either.......must be a bug unique to the MAC side.
Hopefully, GS will look into this.
RM
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
