‎2004-03-23 08:28 PM
‎2004-03-24 01:11 AM
rm wrote:Yes--though the window doesn't completely disappear in plan--just various elements, like sills, or when viewing actual line weights, parts will show incorrectly. It's most definitely a bug, and one I had not encountered before 8.1. In fact, I first noticed it just a few days ago.
Using AC 8.1 doors or windows has been very frustrating. When adjusting them, stretching, changing parameters in plan, I find them disappearing on screen even in plan after rebuilding or refreshing the screen. Yet they show up in 3D just fine.
Is anyone else experiencing this?
‎2004-03-24 02:14 AM
‎2004-03-24 02:54 AM
‎2004-03-24 06:30 AM
rm wrote:Are you using SEOs on the walls where the doors and windows misbehave?
Thanks Dave for confirming this. If you are experiencing the same problem, I would encourage you to let Tech Support know about it. When I talked to them about it today, they indicated that had not seen this before.
‎2004-03-24 07:32 AM
Djordje wrote:Not in the most recent occurrence. I'll have to go back and check the previous one. Is that a relationship you've found to exist?rm wrote:Are you using SEOs on the walls where the doors and windows misbehave?
‎2004-03-24 08:33 AM
‎2004-03-24 05:00 PM
Are you using SEOs on the walls where the doors and windows misbehave?SEO? I'm afraid I have not seen SEO before, what do you mean.
‎2004-03-24 05:23 PM
rm wrote:Solid Element Operations. Djordje was suggesting that the problem might be tied to its use, but not the case in my experience.
‎2004-03-24 05:33 PM
