Scott Bulmer
AC10 will not publish WMF
Please see error message when trying to publish to a Windows Metafile. Is there some licensing restriction as implied?
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
6 Replies 6
Djordje
Which type of views are not saved?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Scott Bulmer
Thanks Djordje,
The AC10 PLN only contains Layouts originally created in AC9. The layout sheets contain PMK & JPG drawings only.
Is the file trying to publish PMK's? They are no longer supported for output in AC10.
Scott Bulmer
Thanks Matthew,
Yes, PMK's are in the Layout sheet. I was afraid of that.
Scott Bulmer
Update:
We were unable to publish to WMF using AC10 view set drawings only. The same error message came up. Issue is not limited to PMK files.
Haneef Tayob
Hello
It seems that one cannot publish a layout to .emf or .wmf
If I try to publish a view however, then it is able to do so.
I'm trying to bring in a complete layout into coreldraw.
If I publish to tiff or jpeg, the image resolution is very poor. If I copy-paste individual items from an AC layout into CorelDraw, the quality is as good as an AC10 layout. The problem is that I loose my titles and have to reorganise the layouts into CorelDraw. I also have to re-do the process everytime something changes. CorelDraw can read pdf's but for some reason CorelDraw is also not accepting AC10 layouts published to pdf.
Any suggestions?
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
