Installation & update
AC24 Bug Reporter on macOS
schagemann
With AC24 there seems to be a new Bug Report interface, which at least visually looks much improved over the previous version.
Unfortunately, though it seems that on macOS you can not opt to quit or cancel the new Bug Report without submitting a report... ironically for us only 'Force Quitting' the Bug Report seems to work for us.
Has anyone else noticed this?
macinteract
Design Technology Managers - all  on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
10 REPLIES 10
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you for the suggestion! I passed your request to the designer. I hope that we'll be able to create a better UI for the Bug Reporter in the next releases!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
