AC26 takes over
Djordje
Hi guys!
Although I am (very) old school and prefer to start the software, and then open the file, I have noticed that, since installing 26, any OpenWith Archicad 25 action in File Explorer results in the file opening in 26... it is good if you notice, can be messy if you do not...
Anyone else?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Emre Senoglu
You can change this back. Assuming you're on windows here's how: https://capture.dropbox.com/jeBoTtaGhdM53KTc
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
www.senoglu.co
Thanks, Emre, I know 🙂 That is why I have reported the issue. The files are already set to open with 25, but they open in 26 instead.
undefined
Djordje
HP Omen
Benjamin Dani
Thank you for sharing this issue!
I wonder if you have already tried setting this up from the Windows settings?
Please read this article carefully, it has some interesting information which might be helpful in this case.
I hope it helps you solve the problem!
Kind regards,
Dani Benjamin
Technical Support Engineer
