Achille Pavlidis
AC29 mac Icons appear truncated
Hi, I recently installed AC29 (build 3100 INT FULL) on a mac mini with M2 pro and OS 13.7.8 and the icons on the elements settings appear truncated like in the screenshot
Any ideas how to fix this?
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
18 Replies 18
runxel
Yeah, by updating your macOS. 😅 You are four versions behind – Graphisoft only supports two back. So right now that would be 26.x and 15.x.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Achille Pavlidis
Well, I did update my OS to the newest version, and I still have the same problem
On other macs in the office that have the same macOS version, the problem does not appear...
Is it a dark mode issue?
That looks like you have dark mode on?
Achille Pavlidis
no, it's not. I tried the standard mode and it's the same
Lee Hankins
That’s a weird one. We’re using 29 on MacMinis with M2 and M4 and haven’t seen the same issue.
Do you have a non-standard screen resolution?
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Achille Pavlidis
Wouldn't say so.
Screenshot 2025-11-11 at 1.04.18 PM.pngScreenshot 2025-11-11 at 1.04.11 PM.png
Nicholas Jones
Did you find a solution to this? I just got round to updating and am having the same issue.
AC25 solo UK • 2017 MacBook Pro 15" 2.9GHz Quad-core i7 16 gb ram
OSX10.15.5
Nicholas Jones
 I have just updated everything and it seems certain element settings, and the standard toolbar are affected, others seem fine.
OSX10.15.5
Achille Pavlidis
When I change the mode to "Light" on system settings the images appear OK. Then I change AC work environment to match my device, turn the mode to "Dark" and the icons appear OK
But then, once I quit and reopen AC everything goes back appearing truncated...
