2025-11-06
02:58 PM
2025-11-06
10:18 PM
Hi, I recently installed AC29 (build 3100 INT FULL) on a mac mini with M2 pro and OS 13.7.8 and the icons on the elements settings appear truncated like in the screenshot
Any ideas how to fix this?
2025-11-06 04:04 PM
Yeah, by updating your macOS. 😅 You are four versions behind – Graphisoft only supports two back. So right now that would be 26.x and 15.x.
2025-11-07 02:05 PM
Well, I did update my OS to the newest version, and I still have the same problem
On other macs in the office that have the same macOS version, the problem does not appear...
2025-11-07 03:15 PM
Is it a dark mode issue?
That looks like you have dark mode on?
2025-11-08 05:15 PM
no, it's not. I tried the standard mode and it's the same
2025-11-08 05:29 PM
That’s a weird one. We’re using 29 on MacMinis with M2 and M4 and haven’t seen the same issue.
Do you have a non-standard screen resolution?
2025-11-11 12:05 PM
Wouldn't say so.
2026-01-02 02:00 PM
Did you find a solution to this? I just got round to updating and am having the same issue.
2026-01-02 05:31 PM
I have just updated everything and it seems certain element settings, and the standard toolbar are affected, others seem fine.
2026-01-22 11:56 AM
When I change the mode to "Light" on system settings the images appear OK. Then I change AC work environment to match my device, turn the mode to "Dark" and the icons appear OK
But then, once I quit and reopen AC everything goes back appearing truncated...
