2006-04-03 01:05 AM
2006-04-03 05:48 AM
Well, on a PC, obviously it is 'shift-alt.'This could be your first mistake. Think of it as alt-shift if you can. And when you execute it, hold down alt and then shift. Keep them both pressed until you have successfully relocated your user origin - when you are done let go of shift and then alt.
2006-04-03 06:57 AM
Link wrote:really? what happens when you are on-the-fly and holding down shift as a part of the constraint operation (which is normal behaviour)? all i have to do is tap the ALT key with my thumb (on-and-off): origin gets reset and constrained angle is still constrained . . . ready for next command . . .Well, on a PC, obviously it is 'shift-alt.'This could be your first mistake. Think of it as alt-shift if you can.
2006-04-03 07:06 AM
2006-04-03 07:16 AM
Link wrote:ah! so pressing ALT for menu items is actually a toggle? flicking it again toggles it off and places the user-origin at the same time?
In your case PC users have to either hit ALT twice or let go of shift.
2006-04-03 02:26 PM
Link wrote:I know you're joking, but I'd rather blame Graphisoft. That's a pretty goofy quirk.
Hey blame Bill mate!
In your case PC users have to either hit ALT twice or let go of shift. Guess we just have raise our finger that millimeter and lose that nanosecond.
Link.
2006-04-03 02:29 PM
Link wrote:Thanks, Link. That also helped.
