ARCHICAD 17 ERROR
I was trying to render something and Archicad 17 crashed. I opened it back up did a save as and thought everything was fine. Since then Archicad 17 throws the error "Cannot create temporary files" and then closes. How can I fix this. I tried uninstalling and reinstalling and it does not fix the problem.
3 Replies 3
If a reinstallation did not resolve the problem, then perhaps Preference Cleaning will help:
http://www.archicadwiki.com/PreferencesCleaning
If you've customized your work environment, you might export it first so that you can import it again without having to set it up again.
preferences cleaning worked thank you so much!
Glad it worked. 🙂
