Help!!!! my 3D perspective doesnt work..........
I try both of them, but still doesn't work and also it switch to axonmetry when I change the setting.....
4 Replies 4
Try the Zoom Extents button when in perspective, or check your 3D projection settings and see where your camera and target are.
I tried "fit in window" in perspecective, but doesn't work.... and I tried the setting as well, but everything it switch to axonometry automatically and nothing change.......help....
What do you mean by "it doesn't work"?
Can you do a New & Reset and see if it works then?
Could it be related to graphics card driver problems as is the case many times? Downloading and installing the latest graphics card driver may help that.
I had the same problem just a few days ago didn't seem to find out why it happened but what i did to fix it was, just dragged a new copy over from the 'Project map' to the 'View map' an it seemed to work.
Make sure you do this 1st before deleting the old perspective, as if you delete it 1st it will then make the perspective in the 'Project map' act up too, an i dont know how to fix that.
Once you have made the copy then delete or just leave the old perspective in the 'View map'.
Hope this helps.
