HK ARCHITECTURE
ARCHICAD 27 - Slow zoom and pan
I recently been using Archicad 27 and i clearly notice that this version is very slow when i pan and zoom (in or out) in 2D. It seems to get worse the more time i spend working and the more object the project has displayed. This does not happen in 3D. The zoom is slower when the mouse is over an object or wall or something...I worked before on Archicad 25 and never had this issue. The PC specs are good : I9 13900KF, RTX 3090, 64GB RAM, SSD disks...
Can someone give me some advice to what's seems to be happening here ?
Thanks !
HK ARCHITECTURE - Kévin PAIVA (France / Portugal)
Archicad 27
Windows 11 / I9 13900KF / RTX 3090 / 64GB RAM DDR4 / UltraWide Monitor
24 Replies 24
jdub_iom
Hi @joelsdg, sent this thread and a bit of info about the problem existing since AC26 to local support and got the response of "system requirements", they even said my M1pro wasn't good enough (Recommend M1 Max and above according to them).
Doesn't really help us and we do feel annoyed that we've upgraded. The huge price increase in April made us jump to AC27 before we needed to to get the cheaper rate. AC22 was more than enough for our needs and now we have Monterey installed on our iMacs it isn't really stable enough to use.
Think we are going to struggle along with reduced graphic settings until M4 Macs come out.
Archicad 27 Solo
Mac OS 15 (M4pro Mac Mini)
joelsdg
Thank you for going through all of that trouble to get more information, jdub, I really appreciate it.  I'll consider going the same route with Graphisoft North America, to see what they say.  Thank you, again.
It does make me wonder if I should recommend cancelling the annual subscription if we can't trust Graphisoft's "Hardware Requirements" list.  We tend to keep our Macs for several years because they "just work". And we don't need the latest/greatest software every year or two if the hardware upgrades are also required.
AC 6.5-28; macOS Tahoe; 2021 MacBook Pro M4 Max
HK ARCHITECTURE
   Hi, @Tamas Gaspar ,
Iam sorry to bother you with this subject, but since you've helped me with the 28.1.0 version crashes Topic las week, I wanted you to submit a topic/issue that has been lasting since the Archicad 26 release and has not been solved correctly since then.
It is a problem that many users have : the slow zoom and pan in while using Archicad on a 2D drawing.
@MASz "solved" the issue by indicating some changes to do on our PC Regitry Editor, but the heart of the issue is, I think, in the Archicad configuration system itself. There must be something that Graphisoft can do to improve and definitly/correctly solve this issue. For example, the new Archicad 28 release still has this problem. I had to do all the things that @MASz told me before to be able to use Archicad 28 correctly...Honestly, I am not a Pro and do not understand the technicality of the issue here, all i know is that I could not use the most recent versions of Archicad before the @MASz posts, and that a real problem here as I believe many other users could be facing the same problem and not have the chance to know where to look for answer, or worse, believing that the most recent versions are just slower that Archicad 25 (that what I believed for years !!).
I apreaciate all the effort you could do to report and try to solve this matter that is essential for the sucess of Archicad.
Best Regards,
Kévin PAIVA
Archicad 27
MASz
I would say that all Windows users would be experiencing the same problems in 2D. However, in general that just doesn't really seem to bother Graphisoft.
At least the 3D window has been fixed.
AC28 AUS, Windows 11, i9 14900K, RTX5090, 128GB DDR5, 4k144 display
Karl Wir_n
Thank you so much!
This issue with the 2d-window being sluggish to a degree of not beeing able to get work done i Archicad has been so frustrating to our office. I folowed your instruction and now things run much quicker and without that blue circle just spinning forever everytime you zoom or pan.
