2003-11-20 11:28 PM
2004-01-01 01:33 PM
2004-01-05 10:19 AM
2004-01-05 10:43 AM
gkmethy wrote:Well, this doesn't fix my problem. I tried my key on a PC and it still gave the not responding error. I have to assume the key's rom has been corrupted???
If you run ArchiCAD 7.0 / 8 /8.1 in native mode, the Kernel extension must be installed, otherwise you will get key not responding errors. The kernel extension will however disable ArchiCAD in Classic with WIBU key.
2004-01-05 08:14 PM
Mathilde wrote:The hub has to be powered. The Cube especially does not have enough power to run all the USB devices if all the slots are full.
A long time ago it happened, when I plugged the protection key into the USB hub.
2004-01-08 08:46 PM
2004-01-09 08:15 AM
Tim wrote:It is. BG ArchiCAD also takes up a license - so if you have 7 people working in ArchiCAD and updating the layout books in PlotMaker at the same time, they are using 14 licences.
The WIBU keys may be looking at the number of AC sessions open rather than users logged on, I'm not sure.
2004-01-09 04:02 PM
Djordje wrote:This seems like a REALLY bad deal for network license users. The local key allows both (or many) sessions to run without any trouble. I am surprized that this is the case, and surprized that the network licensees aren't screaming about it (yet).Tim wrote:It is. BG ArchiCAD also takes up a license - so if you have 7 people working in ArchiCAD and updating the layout books in PlotMaker at the same time, they are using 14 licences.
2004-01-09 04:33 PM
2004-01-09 09:13 PM
Tim wrote:Oops, my bad! That was the case with one of the previous versions ...
Well, we retsarted the WIBU application this morning and have had no problems, We also ran some simple tests and had several users open multiple sessions of AC. With all 15 users working in AC and at least 4 users opening 3 to 4 sessions of AC we had no issues. While this is not a highly scientific test, it does seem to indicate that the key is pinging users, not sessions.
