Installation & update
ArchiCAD 13 and the file converters
After installing ArchiCAD 13 on Mac OSX 10.5 I noticed that the file converter versions (9.0 and 7.0) stopped recognizing the protection key.
On the Windows BootCamp partition where only AC12 was installed I could get them working with a 12 key, but not with the key which has been upgraded to 13.
Has anybody had some similar problems?
I would guess that it is a WIBU driver version thing. See:
http://www.graphisoft.com/support/archicad/downloads/WIBU.html
perhaps you need to reinstall 5.20b
(For OS 10.6, the converters work with the 5.3 and the wkmac.lib listed there.)
Excellent guess!
it worked, thank you
Glad it worked, Ferenc! 🙂
