‎2011-08-29
09:26 AM
- last edited on
‎2024-04-02
02:25 PM
by
Aruzhan Ilaikova
‎2011-08-29 04:54 PM
‎2011-08-29 06:37 PM
Marton wrote:
Nicola,
based on the screenshot something went wrong when patching TWClientBase.dll. Try to disable your Anti-Virus solution (the best is disconnecting all network connections for the period), that might block the installer. Then insert ArchiCAD DVD and run the installation, it will find your current ArchiCAD instance so will run in repair mode. After it will be repaired apply the hotfix again.
Let us know the result,
Marton
‎2011-08-31 09:13 AM
Nicola wrote:In such cases it is important to make sure that all files are ok, with a full repair install this can be done.
But why do you not make a possibility to repair only the last hotfix installed (not the double passage repair Archicad and reinstall Hotfix)?
