2021-01-25 04:27 PM
Solved! Go to Solution.
2021-01-28 10:21 PM
Karl wrote:Karl -
rm wrote:Other subscription software ceases working when the license is terminated if the subscription is not renewed. (Well, it varies. Other stuff becomes at least feature-crippled - e.g., Adobe Lightroom becomes read-only, other Adobe software ceases to work. Quicken looses the ability to download. Etc.). Hence, it is important to emphasize what Barry posted since all kind of people new to ARCHICAD or even just looking at ARCHICAD may come across this thread via a search. Your license is active indefinitely. Ending SSA does not end updates to THAT version... and updates are released for up to a year or more after the next version is release. It only ends priority support and updates to new releases.
I never stated that you can't continue the use of the current software, that's a given. I stated they terminate your license ( as in SSA ) which means no next update or priority support.
All of that said, sorry to hear that you upgraded to Big Sur. I've continued to postpone the upgrade. We've been in this situation with prior MacOS updates and it is most unfortunate for people purchasing new Macs as they have no option but to run the most current MacOS.
2021-01-28 11:14 PM
2021-01-29 12:51 AM
2021-01-29 02:09 AM
rm wrote:
If you or any other moderator don't agree with my premise here, that doesn't make you right or me wrong. It means you have a differing opinion. A courtesy notification of the thread being moved would have been appropriate and professional.
Let us not make this forum like Twitter, FB, and the like; that sensors opposing views to those of the "gatekeepers". This forum is supposed to be an exchange of ideas, whether you consider them useful to you or not. I hope in the future, the moderators here will exercise a little more judicious restraint before choosing to squelch descending opinions about the software.
2021-01-29 12:21 PM
rm wrote:Full agree but it isn't just with the OS, there have been a few headline marketing promises that have not yet appeared, polygon openings and an update to the MEP system are two that come to mind. I know the world is experiencing a crisis but these kind of delayed deliveries predate the current situation and are frustrating if your workflow would benefit from them, especially when you pay your subscription based on what was in the headlines. Back to the main point though, GS knows when the next MacOS is due and some users for various reasons need to keep their OS up to date, telling them that they should wait when other developers are announcing compatibility and new upgrade features is at best irritating.
The point of my post is to state - GS is not updating AC fast enough to keep up with Apple OS changes - FULL STOP!
2021-01-29 02:00 PM
2021-01-29 02:13 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-01-29 05:54 PM
Robby wrote:Exactly!
Robert,
I guess the point of your original post was that AC24 does not work well with Big Sur.
2021-01-29 06:02 PM
mnguyen wrote:
Dear all,
Thank you very much for your comments and I am truly sorry for the troubles and inconveniences!
As you probably know, we noticed a strange behavior called "heap corruption" crashes, that is happening since macOS Catalina. For more information, please have a look at this article. This issue seems to affect a small number of users with AMD graphics cards. Even though Big Sur has been released for quite a while now, we found that in some of our test machines, the heap corruption crash tends to get worse. Because of this issue, we do not recommend updating to Big Sur yet.
Nevertheless, if you encounter any issue with Archicad running on Big Sur, feel free to reach out to us via local support, or directly to me, and we will be very happy to help!
As far as I know, we did not receive any report regarding Archicad 24's speed on Big Sur, so I think this could be a rare issue. I personally tested Archicad 23 and 24 on Macbook Pro M1 (of course it is on Big Sur), and found no serious performance problem. Robert, if the problem happens with one particular file only, could you share with us the file you are working on and the way to reproduce the slowness for further investigation?
If the problem is not file-specific, we will need to collect some logs, called "Sample Process" when Archicad becomes slow, but please let me know which one is the case.
Thank you very much for your understanding! Looking forward to hearing from you!
Best regards,
Minh
2021-01-29 06:20 PM
