Installation & update
ArchiCAD 27 crashes on opening
Hello!
I have a student license for ArchiCAD 27.
I am using it thorough server with a collogue. We tried the VPN but it won't work so we tried with a solution found online: Hamachi. It worked well, we were able to connect to the server and work for our project.
But since last week, it crashes on opening. I want to know if the crash is happening due to the server and Hamachi, as being kind of a third party? Or is it due to something else?
I have attached here a screen capture with the crash report since I cannot attach a .txt file here (verified and it is the same content each time it crashed), and I have send it anyways when the bug reporter dialog box appeared after the program crashed.
1 REPLY 1
If it worked before, there should be no reason why it shouldn't work now, unless something has changed in your setup.
Is Archicad crashing before you try to open a file?
Or will it let you open a new file from the template?
If it is only this particular file that crashes, try to open it with the 'Open & repair' option selected (from the FILE > Open menu in Archicad).
