2017-09-19 04:07 PM
Solved! Go to Solution.
2018-02-07 02:32 PM
Paul wrote:Hi,
Looks like that update for AC20 last year never happened, which means I am pretty much crippled on projects still running under AC20. When will AC20 realistically be patched with a windows 10 Creators update DPI fix now?
2017-09-20 01:34 PM
Paul wrote:Yep, same problem here.
Is anyone else finding that on a 4K screen, following the recent Windows 10 Creators update, that the ArchiCAD mouse pointer is now insanely small? (for all ArchiCAD versions)
2017-09-20 03:28 PM
230368 USER INTERFACE: For Ultra High Definition (4K) screens, mouse cursor appeared small inside ARCHICAD in Windows 10 with Display Scaling enabled.
2017-09-20 03:58 PM
2017-09-21 03:42 PM
2017-09-21 04:17 PM
2017-09-21 04:31 PM
Erwin wrote:Thanks Erwin. After patching with preview 4004 update I discovered the problem can now be solved by also toggling DPI scaling compatibility settings on then off again as above - but ruler trick will help people waiting for the official release
Not helpful for the size, but if you find you keep losing the cursor, you can enable rulers, right click in them and choose cursor projection. You get cross hairs on your screen.
A bit of a hidden feature, so thought I'd mention it.
Would be nice if this gets fixed for whenever we do upgrade from HD screens to 4K, though.
2017-09-22 08:34 AM
2017-09-23 08:00 AM
2017-09-26 06:29 PM
