ArchiCad 9 US - Wall intersection voids remain after trim
I am experiencing a problem of voids, or gaps, remaining in walls after other trimmed walls have been moved or deleted. It is almost as if the 'ghost' portion of the removed wall remains and shows itself in any wall contacting it. Any suggestions. I have already installed the new patch.
7 Replies 7
Are you sure this is not happening when you hide a layer?
Woody
Thanks. I have gone back and checked and it does seem to be what it is, the wall overlapping a hidden wall. Is there a way to turn this condition off or prevent it from happening?
Djordje
Which system/OS?
Video card?
Drivers?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Windows XP Professional 2002
Intel Graphics Controller
If the layers the walls are on have the same intersection index, the point of intersection will not heal when one layer is turned off. They need to have differing intersection indexes. (see attached)
Woody
Thanks. I will try that.
Djordje
In some cases, the gaps do appear just after you trim or adjust a wall. They usually go after a redraw or a rebuild.
If they stay, and show in 3D, than the layer intersection priorities are probably the culprit.
Djordje
HP Omen
