Installation & update
ArchiGlazing Sketch Window problems
fuzzytnth3
Can anyone tell me if there are some tricks to getting ArchiGlazing to work?
I find that quite often when I try to do a sketch window AG says I have to use 2d lines even although thats what I have selected. If I try again with the same bunch of lines it works without any problem.
The other major pain is that I can't get it to do windows with mullions and transomes. I've attached an example.
The version of ArchiGlazing I have is 1.7 and as far as I can find that is the current version.
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Achille Pavlidis
version 1.7 is the newest... works with me... a problem i had some times is that i had a line or two overlapping and this caused problems... you have grouped the perimeter?
Mac OS 26.1 | AC 29.0.2 INT 3200 FULL
fuzzytnth3
Checked for overlapping lines - none found
I gouped the external lines as one group and grouped the mullions and transomes as another group and got the attached result.
Still no cigar
