Archicad 10 launching problem! URGENT help needed
Since yesterday something funny has starated to happen. When i launch Archicad 10, the Graphisoft bug reporter launches and refuses to go even after cancelling as well as sending the report, the Archicad 10 does not launch. Everytime it goes back to the bug reporter and it quits.
6 Replies 6
Srinivas
Are you working on a student/Comercial version? Where are you located in India?
cheers,
Srinivas
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
I have been working on the student version, but a friend of mine who has a commercial version has started behaving in the same manner. The ArchiCAD 10 does not launch anymore it always goes to the bug reporter and it quits. Any solution to this?
Gorazd
First tought would be to try and reinstall Archicad. Usually that helps. Was there any change in hardware or did you install some new software that might mess something up?
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
Srinivas
If the reinstallation doesn't work, then try to change your default printer, if its possible try to delete your printer [this is recommended if you can reinstall the printer drivers again] and start ArchiCAD. You can reinstall ArchiCAD after deleting the printer.
Hope this helps.
ArchiCAD Service
Mac, Windows 11
Djordje
Just a hint to all Indians:
Please put your location in India in your profile too. That way, you could communicate among yourselves if you are geographically near.
And if you are far, in India it is really far away ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Rafal SLEK
Clean also Graphisoft folder from Documents and settings sometimes it helps in such situations - there are located prefs files which are loaded on start.
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Tahoe/Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/
//MSI AMD Ryzen AI 9/2.5GHz/32GB/Nvidia RTX 5070 Ti/Windows 11 Pro
//ArchiCAD Collaborate
