Archicad 13- setup.exe
Acabo de instalar el archicad 13 en español, version para profesores por 1 año, y no lo puedo arrancar ,ya que no me instala el setup.exe.Que debo hacer?
3 Replies 3
The language of this Forum is English so you should write in English.
Do you speak English?
Translation via Google Translate:
emilre wrote:
I just installed the 13 in Spanish archicad, version for teachers for 1 year, and I can not boot, since I installed I do setup.exe.Que
Just had to give it a try
Eduardo Rolon
Actually it says that "I have finished installing AC13 Spanish, educational version, and it does not launch since since it cannot find setup.exe".
Setup.exe es para instalar el programa no para correrlo, debes de tener el archivo de Archicad bajo Program Files -> Graphisoft -> Archicad 13 ->Archicad.
Si no es así vuelve a bajar AC del website y reinstala. Es posible que hay algo mal con el archivo que bajaste.
Setup.exe is for installing the program not to run it. You should have the "launcher" in …
If not redownload AC from the website and reinstall. Something might have gone wrong with the downloaded file.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
