Help - Archicad Preferences file is damaged
I can't start AC 13 as there seems to be a corrupted preferences file. I did a search and found locations to delete these files listed for Windows XP on version 12 but I am using Windows & 64 bit and can't find the same locations. Does anyone know where this file or files are located.
Thanks,
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
8 Replies 8
alemanda
Me too ... I have the same problem.
Help. I cannot start AC13 on my laptop.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
Alemanda,
I think what I eventually did was uninstall AC13 and delete everything I could find in the Registry, Documents, and Programs folder if there was anything left over after the uninstall. You might have to make hidden files and folders visible in Explorer. It was then OK. I phoned AC tech support and they had me delete some files but it didn't work. Hope this helps you.
Gerald Hoffman
On Windows, these are the places where you can find Graphisoft preference files. This in on Vista:
C:\Users\<Username>\Application Data\Graphisoft
C:\Users\<Username>\Graphisoft
C:\Users\<Username>\Local Settings\Graphisoft
alemanda
Which of the three folders?
I have some TW projects and I don't want to delete important files?
Thanks
AC27 latest hotfix
Win 11 Pro 64bit
Ralph Wessel
Thanks
Try moving the basic preferences file somewhere else (rather than deleting it) to see if this fixes the problem. You will probably find it somewhere like this:
C:\Documents and Settings\<User Name>\Application Data\Graphisoft\ArchiCAD 13.0.0 INT R1\ArchiCAD Basic.prf
You can delete the moved file if the problem is solved.
Ralph Wessel BArch
Central Innovation
Hello
I have a problem with my ArchiCAD13 (64 bit). I use student version and I'm using Windows 7 OS. When I try to start my Archicad13, I have information that my preference file is damaged. I don't know what I have to do. I must end my project on Monday
Please reply quickly
Ralph Wessel
Did you try the fix I suggested in my previous post?
Ralph Wessel BArch
Central Innovation
In windows 7 is a different path to the file, but I found it. Thanks 4 help. Below I write a localisation for Windows7.
C:/Users/<user name>/AppData/Roaming/Graphisoft/ArchiCAD-64 13.0.0 R1/ArchiCAD Basic
