‎2019-04-08 01:16 PM
‎2019-04-08 02:20 PM
another Moderator
‎2019-04-08 02:42 PM
‎2019-04-08 03:07 PM
‎2019-04-08 03:12 PM
ejrolon wrote:If I understand correctly this is your issue. When you turn ON layer C in 3D it remains off in 2D since AC does not updated layer states across Tabs (for that you need to have them linked as David indicates). This behavior was changed IIRC in AC21, eventually you get used to it.
…. All tabs in AC can have different Layer states so when you switch from one to the other options will defer. You can copy the Layer State of a tab to another by rich clicking in a tab, choosing "Pick Up Settings" and then right click in the desired tab and using "Inject Settings".
another Moderator
‎2019-04-08 03:21 PM
‎2019-04-09 01:59 PM
‎2019-04-12 09:42 AM
‎2019-04-12 09:51 AM
‎2019-04-12 10:08 AM
